ABIT KT7 + DURON (MORGAN) 1200
beemf ::
a gre to dvoje skupaj oz. ali ima kdo v taksni navezi in mu deluje?
Beemf
kuglvinkl ::
Morda ti BIOS ne podpira takega množilnika, tako da, najprej flešaj z zadnjim BIOom, potem bo ziher delalo. Ok, najprej v SoftmenuIII poglej, do kje lahko nastaviš množilnik pa postaj.
freejack ::
KT7/KT7-RAID: 100MHz (200MHz DDR) FSB processors only. Fastest processor supported is the Athlon 1400(100) - but it must have locked (disconnected) L1 bridges. AthlonXP processors are not and will not be supported. All Duron and Duron (Morgan core) processors are supported.
KT7E: As for KT7/KT7-RAID although unofficially many users have also succeeded with 133MHz Athlon processors. Although the AthlonXP is not officially supported, several people have told me that they using one without problems.
KT7A/KT7A-RAID versions 1.0 to 1.2: All Athlon (Thunderbird) processors with both 100MHz and 133MHz FSB. AthlonXP processors are not officially supported due to a minor timing problem that can require you to hit reset during a cold boot. Unofficially, however, few people seem to experience this problem and these processors work fine.
KT7A/KT7A-RAID versions 1.3: All Duron, Duron (Morgan core), Athlon (Thunderbird) and AthlonXP processors are supported.
  • spremenil: freejack ()
ABIT KT7A + Duron 1800 = unknown CPU
161890 (1756) Dr_M
Neuradno kateri max CPU podpira ABIT KT7A?
252014 (1747) jest10
KT7A + Athlon XP
222529 (2063) Jure2k
Abit KT7A + TB 1,4........
Oddelek: Navijanje
292007 (1653) kuglvinkl
AMD XP proci,...
432662 (1818) SlaveMaster
