Forum » Operacijski sistemi » not enough storage is available to process this command ???
sith ::
Oj.
Postavljen imam server 2008 in želim uporabiti KMS klienta za licenciranje računalnikov v domeni...... da ne bom predolg.... ko hočem štartat inštalacijo KMS klienta mi napiše "not enough storage is available to process this command" .
Ali ima kdo kako idejo kaj bi lahko bil problem?
- spremenil: sith ()
Rotaidal ::
Do one of the following, then retry the command: (1) reduce the number of running programs; (2) remove unwanted files from the disk the paging file is on and restart the system; (3) check the paging file disk for an I/O error; or (4) install additional memory in your system.
http://technet.microsoft.com/sl-si/libr...
| » | Kako izklopiti page fileOddelek: Pomoč in nasveti | 1065 (946) | gzibret |
| » | Koliko placa za Visto?Oddelek: Operacijski sistemi | 2226 (1876) | Pesimist |
| » | Your sistem is low on virtual memory?Oddelek: Pomoč in nasveti | 1578 (1417) | Nettisunny |
| » | win 2000 virtual memory to lowOddelek: Operacijski sistemi | 1858 (1684) | civava23 |
| » | Kako razdeliti 250GB disk? (strani: 1 2 )Oddelek: Pomoč in nasveti | 7132 (6245) | bajsibajsi |
