Forum » Programska oprema » NTFS v FAT ne gre zaradi sparse f. kako?
Barti ::
Imam Win2000, NTFS. Rad bi spremenil v FAT s Partition Magic 7, pa javi, da imam nekaj sparse files in compressed files. Da jih moram odstraniti. Kako jih najedem in odstranim.
Ne bi rad ponovno naložil Win2000.
Še eno vprašanje. Kako .eml file spremnim v txt ali doc file.
oknaj ::
Rad bi inštaliral Win98 na mašini, ki ima že inštaliran Win2000 in ta mora ostati. Imam isti problem. Si ga ti že rešil? Če ja, kako?
lp Janko
lp Janko
(sic) ::
Najdi fajle, ki jih maš kompresirane iz jih "odtisni".
Aja, pa downloadaj si Partition Magic 8 - glede na 7 huda izboljšava.
oknaj ::
Evo rešitve, to sem že enkrat naredil in nato pozabil. K sreči je filet ostal:
To fix the error:
1. Bring up a command window within NT/Windows 2000.
2. Change to the root directory of the affected drive.
3. Enter the following at a DOS prompt: COMPACT /U /S /I /F *.*
4. Perform a search for the file EGA.CPI. When you find the file, right click on it,select Properties, select Advanced, and verify that the file is uncompressed. You should now be able to perform the conversion without getting Error 1681.
If you still get Error 1681, then load Windows 2000 or Windows NT again and search for compressed files manually using Windows Explorer. For more information on this procedure, see PowerQuest Solution PR998, "Uncompressing files in Windows 2000 Professional," or PowerQuest Solution PR1036, "Uncompressing Files in Windows NT."
This error can also be fixed by deleting any sparse files, uncompressing any
compressed files (using the Windows NT COMPACT /U command), and re-running
PartitionMagic. The FRS number for the compressed file is displayed in the Error 1681 text. At a command line prompt, use the following command to obtain the file name that corresponds to the FRS number: PqFile /FRS:
Problem Description Error 1681 Data is compressed or sparse, File %lu (%lu). Click OK to cancel
conversion.
Error 1681
To fix the error:
conversion.
Error 1681
| » | Namestitev Windows 7 z USB ključkaOddelek: Novice / Operacijski sistemi | 18488 (16508) | mtosev |
| » | Apache - localhost JA, IP naslov NEOddelek: Omrežja in internet | 7284 (7143) | ManDriver |
| » | Internet explorer se ugasa - sam od sebe... HELP !Oddelek: Pomoč in nasveti | 2090 (1978) | jarni2 |
| » | trdi disk hitachiOddelek: Strojna oprema | 2532 (2167) | kerrigh |
| » | Pomoč z HPT370 UDMA/ATA 100 RAID ControllerOddelek: Pomoč in nasveti | 2999 (2906) | Nocko |
