[JAVA] Uvoz knjižnice v Eclipse
N-E-O ::
JFreeChart library moram nekako uvoziti v projekt in to storim po naslednjih korakih (google):
Steps:
1. Start Eclipse 3.0. (If you do not have Eclipse installed, visit www.eclipse.org.)
2. Go to File -> New -> Project....
3. Select Java Project and click on Next. Enter in a project name and click Finish.
4. Select the project in the Package Explorer view. Go to Project -> Properties.
5. Click on Java Build Path? on the left-hand side of the dialog box and on the right-hand side
click on the Libraries? tab.
6. Click on Add External JARs...? and locate jfreechart-1.0.0-pre1.jar and jcommon-1.0.0-common.jar.
Click on OK.
7. Select the project in the Package Explorer view. Go to File -> New -> Package. Give the package
a name and click on Finish.
8. Select the newly-created package in the Package Explorer view. Go to File -> New -> Class. Give the
class a name and click on Finish.
9. You are now ready to start using the JFreeChart library!
Ko importam določene pakete, mi jih ne najde. Preprosto podčrta mi jih rdeče npr:
import org.jfree.chart.ChartFactory;
import org.jfree.chart.ChartUtilities;
org.jfree mi podčrta da ne najde.
Kaj bi lahko bil vzrok temu?
Follow the white rabbit.
N-E-O ::
Sem zrihtal. Namesto .jar sem uvažal kar celotno .zip.
Premalo izkušenj na tem področju pač.
win10 disk cleanup - avtomatsko
131045 (874) Ijus
Šifrirana mapa
Oddelek: Operacijski sistemi
92831 (2302) amigo_no1
Windows 7 Installer (64-bit) - težave
Oddelek: Programska oprema
153704 (3094) fr!Xy
Logitech MouseWare bug (?)
272600 (2196) Swiwer
RA2 preko dveh modemov?!
Oddelek: Igre
101792 (1687) bastadu
