BitTorrent Tracker
BitTorrent Tracker
hamax ::
Ker mi http ter ftp serverja ne zadoscata vedno, sem se odlocil postaviti se torrent tracker za lastne potrebe.
Problem pa je nastal, ker sem na netu nasel le zelo kompleksne projekte, ki pa povrhu ponavadi se delujejo ne.
Jaz potrebujem le zelo preprost tracker, ki ima zelo enostaven web umesnik.
No, tudi ce ga nima, ne bo nic narobe.
Nasel sem Open Tracker, ki pa ne deluje. Dopuscam tudi moznost, da sem sam kaj pogresil, ampak v to zelo dvomim.
Vcasih mi celo uspe poslati kak file, vendar je tak dogodek prej izjema kot pravilo.
Link: http://www.whitsoftdev.com/opentracker/
Torej, ce kdo pozna kak kvaliteten in preprost torrent tracker, bom zelo vesel.
Hvala
Does µTorrent have an embedded tracker?
Yes, it does. You can turn it on by enabling bt.enable_tracker in the Advanced section. However, it is a very simple tracker, with no web interface, or even the ability to see what torrents are hosted on it. It is not designed for anything requiring security or large-scale.
Once you have enabled it, you can use it by simply putting the tracker's URL into a torrent. The tracker URL is your.ip:port/announce (port being µTorrent's incoming port). IP can be external or internal, depending on if you want to use it in a LAN or across the Internet.
hamax ::
Sem pozabil omeniti, da mora delovati pod linuxom in brez GUI.
Tr0n ::
Google is your friend.
hamax ::
Vceraj sem pregledal ene 30 strani na googlu in prebrskal cel sourceforge, tako da ce nimas cesa pametnega za povedat, bodi drugic raje tiho.
Tr0n ::
Hmm. Ce si downloadas original bittorrent python tracker tukaj in sledis tem navodilom, ti ne dela?
Skoraj dvomim, da ne bi delalo.
PaX_MaN ::
hamax ::
Edit @tr0n
No, tega pa nisem nasel :D
Mogoce zato, ker sem se prevec usmeril v php tracker.
Bom poskusil in porocam.
@tr0n
Bom poskusil, ce se prva moznost ne bo obnesla
Hvala obema.
Tist c++ tracker deluje odlicno. Hvala.
  • spremenil: hamax ()
[P2P] BitTorrent - Naslednja generacija P2P (strani: 1 2 3 4 … 36 37 38 39 )
Oddelek: Omrežja in internet
1904539792 (1063) karafeka
Težava z u torrentom
287566 (5208) MrStein
BitTorrent pohrustal μTorrent (strani: 1 2 )
9117524 (14654) simnov
Kateri P2P je trenutno najboljši?
164174 (3432) wishmaster
eXeem - Decentraliziran BitTorrent (strani: 1 2 3 )
11922261 (13497) OldSkul
