Excel Macro
Excel Macro
gorjanc ::
V excelu imam takle stolpec:
(gor_27272727)
(gor_[807])
(gor_[821])
(gor_[824])
(gor_[836])
(gor_[684])
(gor_[833])
(gor_[867])
(gor_[888])
(gor_930)
(gor_845)
(gor_[964])
(gor_977)
(gor_985)
(gor_1105)
gor_ (gor_)
gor_1002 (gor_1002)
gor_1011 (gor_1011)
gor_1013 (gor_1013)
gor_1017 (gor_1017)
gor_1018 (gor_1018)
gor_1022 (gor_1022)
gor_1029 (gor_1029)
Iz stolpca potrebujem dobiti ven samo številke v vrsticah kjer je številka podvojena je potrebno eno izbrisati. Kakšen pameten predlog kako naj se lotim zadeve?
StratOS ::
No nekaj na hitro Makrič v VB :
Izberi si količino podatkov v vrsticah (23) ter kam ti podatke izpiše stolpec 3
Sub Macro1()
Dim N As Integer
Dim M As Integer
Dim M1 As Integer
Dim Str As String
Dim Char As String
Dim Najdeno As Boolean
Dim Start As Integer
Dim Konec As Integer
For N = 1 To 23   'Recimo 23
Str = Cells(N, 1)
M = Len(Str)
M1 = 1
Najdeno = False
Loop1:
Char = Mid$(Str, M1, 1)
If Asc(Char) >= 48 And Asc(Char) <= 57 Then
    If Najdeno = False Then Najdeno = True: Start = M1
Else
    If Najdeno = True Then Najdeno = False: Konec = M1: GoTo jump
End If
If Najdeno = False Then Konec = M1
If M1 >= M Then GoTo jump
M1 = M1 + 1
GoTo Loop1
jump:
'Rezultate pišemo v stolpec 3
If Start = 1 And Konec = M Then
    Cells(N, 3) = ""  'Prazno
Else
    Cells(N, 3) = Mid$(Str, Start, Konec - Start)
End If
Konec = 1: Start = 1
Najdeno = False
Next N
End Sub
"Multitasking - ability to f##k up several things at once."
"It works better if you plug it in."
"The one who is digging the hole for the other to fall in is allready in it."
gorjanc ::
Zadeva deluje točno tako kot sem si zamislil. Res hvala za tole pomoč.
StratOS ::
Dobro, da smo takoj zadeli v polno :)
mgoza ::
kaj pa takole [8-)]
Public Function NajdiPrvoCeloStevilo(z) As String
    ' funkcija vrne prvo stevilo, ki ga najde v zapisu
    Dim zNak As String     ' posamesen znak v zapisu
    Dim zaPis As String    ' zapis v katerem iscem celo stevilo
    Dim i As Long          ' pozicija znaka, ki ga preverjam
    ' nastavim zacetne vrednosti
    zaPis = Trim(z & "")
    NajdiPrvoCeloStevilo = ""
    ' iscem v zapisih daljsih od 0 znakov
    If Len(zaPis) > 0 Then
        For i = 1 To Len(zaPis)
            zNak = Mid(zaPis, i, 1)
            If IsNumeric(zNak) Then
                ' ce je tekoci znak stevilo ga pripisen iskanemu nizu
                NajdiPrvoCeloStevilo = NajdiPrvoCeloStevilo & zNak
            Else
                ' ce tekoci znak ni stevilo, nasel pa sem ze stevilo zapustim zanko
                If IsNumeric(NajdiPrvoCeloStevilo) Then Exit For
            End If
        Next 'i
    End If
End Function
  • spremenil: mgoza ()
visual basic 2008 express edition
Oddelek: Programiranje
222173 (1600) sel
Visual basic noob question
111908 (1663) DonMatejo
[excel]duplikati
81873 (1800) baksuz
[Excel] problem z makrojem, visual basic (strani: 1 2 )
586761 (6224) steev
kopiranje iz enega fajla v drug??
131554 (1314) Seth
