Forum » Programiranje » Excel Macro
Excel Macro
gorjanc ::
V excelu imam takle stolpec:
(gor_27272727)
(gor_[807])
(gor_[821])
(gor_[824])
(gor_[836])
(gor_[684])
(gor_[833])
(gor_[867])
(gor_[888])
(gor_930)
(gor_845)
(gor_[964])
(gor_977)
(gor_985)
(gor_1105)
gor_ (gor_)
gor_1002 (gor_1002)
gor_1011 (gor_1011)
gor_1013 (gor_1013)
gor_1017 (gor_1017)
gor_1018 (gor_1018)
gor_1022 (gor_1022)
gor_1029 (gor_1029)
Iz stolpca potrebujem dobiti ven samo številke v vrsticah kjer je številka podvojena je potrebno eno izbrisati. Kakšen pameten predlog kako naj se lotim zadeve?
(gor_27272727)
(gor_[807])
(gor_[821])
(gor_[824])
(gor_[836])
(gor_[684])
(gor_[833])
(gor_[867])
(gor_[888])
(gor_930)
(gor_845)
(gor_[964])
(gor_977)
(gor_985)
(gor_1105)
gor_ (gor_)
gor_1002 (gor_1002)
gor_1011 (gor_1011)
gor_1013 (gor_1013)
gor_1017 (gor_1017)
gor_1018 (gor_1018)
gor_1022 (gor_1022)
gor_1029 (gor_1029)
StratOS ::
No nekaj na hitro Makrič v VB :
Izberi si količino podatkov v vrsticah (23) ter kam ti podatke izpiše stolpec 3
Sub Macro1()
Dim N As Integer
Dim M As Integer
Dim M1 As Integer
Dim Str As String
Dim Char As String
Dim Najdeno As Boolean
Dim Start As Integer
Dim Konec As Integer
For N = 1 To 23 'Recimo 23
Str = Cells(N, 1)
M = Len(Str)
M1 = 1
Najdeno = False
Loop1:
Char = Mid$(Str, M1, 1)
If Asc(Char) >= 48 And Asc(Char) <= 57 Then
If Najdeno = False Then Najdeno = True: Start = M1
Else
If Najdeno = True Then Najdeno = False: Konec = M1: GoTo jump
End If
If Najdeno = False Then Konec = M1
If M1 >= M Then GoTo jump
M1 = M1 + 1
GoTo Loop1
jump:
'Rezultate pišemo v stolpec 3
If Start = 1 And Konec = M Then
Cells(N, 3) = "" 'Prazno
Else
Cells(N, 3) = Mid$(Str, Start, Konec - Start)
End If
Konec = 1: Start = 1
Najdeno = False
Next N
End Sub
"Multitasking - ability to f##k up several things at once."
"It works better if you plug it in."
"The one who is digging the hole for the other to fall in is allready in it."
StratOS ::
Dobro, da smo takoj zadeli v polno :)
mgoza ::
kaj pa takole [8-)]
Public Function NajdiPrvoCeloStevilo(z) As String
' funkcija vrne prvo stevilo, ki ga najde v zapisu
Dim zNak As String ' posamesen znak v zapisu
Dim zaPis As String ' zapis v katerem iscem celo stevilo
Dim i As Long ' pozicija znaka, ki ga preverjam
' nastavim zacetne vrednosti
zaPis = Trim(z & "")
NajdiPrvoCeloStevilo = ""
' iscem v zapisih daljsih od 0 znakov
If Len(zaPis) > 0 Then
For i = 1 To Len(zaPis)
zNak = Mid(zaPis, i, 1)
If IsNumeric(zNak) Then
' ce je tekoci znak stevilo ga pripisen iskanemu nizu
NajdiPrvoCeloStevilo = NajdiPrvoCeloStevilo & zNak
Else
' ce tekoci znak ni stevilo, nasel pa sem ze stevilo zapustim zanko
If IsNumeric(NajdiPrvoCeloStevilo) Then Exit For
End If
Next 'i
End If
End Function
- spremenil: mgoza ()
| » | visual basic 2008 express editionOddelek: Programiranje | 2173 (1600) | sel |
| » | Visual basic noob questionOddelek: Programiranje | 1908 (1663) | DonMatejo |
| » | [excel]duplikatiOddelek: Programiranje | 1873 (1800) | baksuz |
| » | [Excel] problem z makrojem, visual basic (strani: 1 2 )Oddelek: Programiranje | 6761 (6224) | steev |
| » | kopiranje iz enega fajla v drug??Oddelek: Programiranje | 1554 (1314) | Seth |
