Quick sort ascending/descending
MarkookraM ::
Ne me tepst ampak nekako ne znam obrniti vrstnega reda quick sorta.
Tale algoritem sortira od najmanjšega do največjega. Kako ga spremeniti, da bo sortiral od največjega do najmanjšega? :8)
public String[] quickSort(String[] record, int begin, int end, Collator Collator)
    String[] tempek = new String[1];
    int i = begin;
    int j = end;
    String mid;
    if (end > begin)
	// Arbitrarily establishing partition element as the midpoint of the array.
	mid = record[(begin + end) / 2];
        // loop through the array until indices cross
        while (i <= j)
	    // find the first element that is greater than or equal to the partition element starting from the left Index.
	    while ((i < end) && (Collator.compare(record[i], mid) < 0)) // maybe here for descending? but it doesn't work :(
	    { i++; }
	    // find an element that is smaller than or equal to the partition element starting from the right Index.
	    while ((j > begin) && (Collator.compare(record[j], mid) > 0)) // maybe here for descending? but it doesn't work :(
	    { j--; }
	    // if the indexes have not crossed, swap
	    if (i <= j)
	     	tempek[0] = record[j];
	       	record[j] = record[i];
	       	record[i] = tempek[0];
	       	i++;
	       	j--;
	// If the right index has not reached the left side of array must now sort the left partition.
	if (begin < j)  quickSort(record, begin, j, Collator);
	// If the left index has not reached the right side of array must now sort the right partition.
	if (i < end)    quickSort(record, i, end, Collator);
    return record_delo;
KaRkY ::
while ((i < end) && (Collator.compare(record[i], mid) > 0)) // maybe here for descending? but it doesn't work :(
{ i++; }
while ((j > begin) && (Collator.compare(record[j], mid) < 0)) // maybe here for descending? but it doesn't work :(
{ j--; }
mislim da je to to nisem pa 100% že dolgo se nisem s tem ubadal
  • spremenil: KaRkY ()
Thomas ::
Moraš zamenjati komparatorje "večji" in "manjši" - pa mora delat!
PaX_MaN ::
Kot je KaRkY zapisal. Glej še, da pravi Collator not vržeš.
MarkookraM ::
Ne, tako tudi ne dela. :(
PaX_MaN ::
Sej pravim, ta pravi Collator mu podaj: http://java.sun.com/j2se/1.4.2/docs/api...
MarkookraM ::
Če pa ascending algoritem deluje.
Tega dobi, ampak ni tukaj težava. Jaz ne znam algoritma obrnit da bi sortiral descending.
Locale localeSI = new Locale("sl", "SI");
Collator CollatorSI = Collator.getInstance(localeSI);
CollatorSI.setStrength(Collator.TERTIARY);
PaX_MaN ::
spremeni v
pa v
MarkookraM ::
Sem probal tak, pa ne dela. Pa po moji logiki in razumevanju algoritma bi moralo. 8-O
Thomas ::
Če boš komparatorje naredil prav (obratno!) - bo delalo, sicer ne.
PaX_MaN ::
Jaz imam tole in deluje:
import java.text.Collator;
import java.text.RuleBasedCollator;
import java.util.Locale;
public class blbl {
	 * @param args
	public static void main(String[] args) {
		// TODO Auto-generated method stub
		String[] b2 = {"aaa","addd","aff", "afde" , "aabe" , "aaee" , "aeef" ,"agge", "aa","a"};
		 RuleBasedCollator en_USCollator = (RuleBasedCollator)
	     Collator.getInstance(new Locale("en", "US", ""));
		String[] o = blbl.quickSort(b2, 0,b2.length-1,Collator.getInstance());
		for (int i = 0; i < o.length; i++) {
			System.out.println(o[i]);
	public static String[] quickSort(String[] record, int begin, int end, Collator Collator)
	    int i = begin;
	    int j = end;
	    String mid;
	    if (end > begin)
	        while (i <= j)
		    { i++; }
		    { j--; }
		    if (i <= j)
		       	i++;
		       	j--;
	    return record;
MarkookraM ::
Tale tvoj algoritem mi sortira od najmanjšega do največjega prvo in drugo polovico recorda posebej. (a, b, c, d, a, b, c, d)
Jaz biti totalno zmeden. :(
Thomas ::
Ti mene posluš!
Samo tam kjer PRIMERJAŠ, primerjave obrni.
MarkookraM ::
Ti pa mene posluš! :P
Sem probal te primerjave obrnit, pa ne dela.
Thomas ::
More delat! Zamenjaš takrat in samo takrat, ko PRIMERJAŠ vrednosti v polju. Ne, ko recimo šteješ in tko naprej.
Jasno?
MarkookraM ::
Meni je jasno moji Java Virtual Machine pa zgleda ni. :D
infiniteLoop ::
JVM-u je vse jasno - dela tocno tiste bucke ki si jih ti naklofal (99.999% casa;)). Ce menis, da si nasel bug v JVM-u :\ ga vsekakor cimprej prijavi.
None of us is as dumb as all of us.
[JAVA] HTTPS client
Oddelek: Programiranje
173694 (2424) peterv6i
Java - sortiranje
81518 (1304) rrejc
[Java] Quicksort
61055 (891) MrBrdo
[JavaScript] Sortiranje šumnikov
152592 (2326) MarkookraM
[Turbo Pascal] Pomoč...
131834 (1736) Grey
