Forum » Pomoč in nasveti » bootable USB ključek
xandros ::
Kako naredim bootable USB ključek, recimo winXP, pa da lahko potem še dodam kakšen program zraven.
- spremenil: xandros ()
StratOS ::
Preglej recimo Kako narediti USB-ZIP boot disk na ključu brez uporabe disketne enote
Program pa Flashboot
"Multitasking - ability to f##k up several things at once."
"It works better if you plug it in."
"The one who is digging the hole for the other to fall in is allready in it."
| » | Po instaliranju USB Debug PC ne zazna android napraveOddelek: Pomoč in nasveti | 2671 (2523) | WinXP |
| » | USB ključ v FATOddelek: Pomoč in nasveti | 7472 (7092) | bbenci2 |
| » | namestitev windows xp z USB ključaOddelek: Operacijski sistemi | 4945 (4234) | Gwanaroth |
| » | Laptop brez OSOddelek: Pomoč in nasveti | 4749 (4056) | ricola78 |
| » | Inštalacija XPjev (in morda Viste) z USB ključkaOddelek: Operacijski sistemi | 2526 (2273) | PrimozR |
