bootable USB ključek
xandros ::
Kako naredim bootable USB ključek, recimo winXP, pa da lahko potem še dodam kakšen program zraven.
  • spremenil: xandros ()
Gwanaroth ::
krofeta ::
StratOS ::
"Multitasking - ability to f##k up several things at once."
"It works better if you plug it in."
"The one who is digging the hole for the other to fall in is allready in it."
Po instaliranju USB Debug PC ne zazna android naprave
102685 (2537) WinXP
USB ključ v FAT
297563 (7183) bbenci2
namestitev windows xp z USB ključa
Oddelek: Operacijski sistemi
174980 (4269) Gwanaroth
Laptop brez OS
254811 (4118) ricola78
Inštalacija XPjev (in morda Viste) z USB ključka
92538 (2285) PrimozR
