Forum » Pomoč in nasveti » trdi disk
trdi disk
ferguson ::
imam naslednje probleme z trdim diskom ko hočem namestiti windowse mi napiše takole
setup did not find any hard disk drives installed in your computer
make sure any hard disk drives are powered on and properly connected to your computer and that any disk related hardware configuration is correct this may invole running a nanufacturer supplied diagnostic or setup program
setup cannot continue to quit setup press f3
kaj moram storiti če zna kdo pomagati havala že za vnaprej
bobby ::
po vsej verjetnosti imaš sata disk, winsi pa ne znajo iskati diske na sata kontroletrju. nekje maš ali cd ali pa disketo, kjer je gonilnik za ta sata kontroler. predno začne inštalarit ti javi, da pritisni f3 za dodatne gonilnike (raid, sata, scsi) in tm prtisneš f3 potem pa slediš navodilom.
ACER TRAVELMATE 5320 - problem pri nalaganju win xp
vista problem
vista problem
| » | Setup did not find any hard disk drivesOddelek: Programska oprema | 2454 (2354) | kratos |
| » | hp 6820sOddelek: Programska oprema | 2338 (2132) | moglasi |
| » | Pri instalaciji Win XP ne zazna HDD (!)Oddelek: Pomoč in nasveti | 2309 (2309) | bluefish |
| » | HP laptop nalaganje win xpOddelek: Pomoč in nasveti | 1819 (1555) | TEDY |
| » | Težava pri nalaganju xpOddelek: Pomoč in nasveti | 1448 (1345) | farko |
