Vprašanje glede CF??
darjo16 ::
Zanima me če lahko v CF povežem Shapire Radeon 3870 in Asus Radeon 3870?
M-XXXX ::
Ja
tilinho20 ::
Ja lahko.
Izi ::
CF ne omogoča samo, da povežeš kartice različnega proizvajalca, ampak lahko povežeš skupaj dve, tri ali štiri povsem različne grafične kartice.
Lahko povežeš skupaj tudi 3870 in 4870, če hočeš.
Oddin ::
Zaenkrat 3870 in 4870 ne grejo v crossfire. Na žalost. "ATI official
Despite previous reports on the internet that old Radeon 38x0 and new Radeon 48x0 cards will work in Crossfire together, unfortunately this won't happen.
Two senior software guys at ATI has just confirmed that 3800 series in Crossfire with 4800 won't work and that such a configuration is not supported.
You won't be able to match the generations and we are investigating if you will be able to mix cards from 48x0 series. We believe you should, but we won’t jump the gun with this announcement.
Sorry for destroying one cool dream, but you will have to forget about your 38x0 card and swap it for a much faster 48x0 generation.
At the same time, our friend W1zzard from tech power up has confirmed that he couldn't make 3800 and 4800 generation cards work together in XP, but now we know the answer why. It won't work on XP or Vista, simply as it's not supported."
ajde
Corsair Obsidian 750D, i5 3570 & 4.4GHz, Sapphire R9 290 Tri-X OC,
CPU+GPU EKWB Custom Liquid-Cooling Loop, Asus P8Z77-V DELUXE, Corsair Vengeance
Pro 8gb 1600MHz, Samsung SSD 850 EVO, Corsair AX860i
Izi ::
Nesposobneži pri ATI-ju, ali pa je to celo namenoma narejeno, da ljudje ne bi mogli uporabljati starih kartic in bi pokupili več novejših.
darjo16 ::
Moje vprašanje je bilo če lahko povežem dve ATI Radeon 3870 različnih proizvajalcev??
M-XXXX ::
In si dobil že OGROMNO odgovorov da se da. Še kaj?
the_game ::
poskusite lahko povezat HD3870 in HD3850 z uporabo Catalyst 8.2 gonilnikov, in deluje normalno
ASUS M2N-SLI DELUXE|AMD Athlon X2 6000|HD3870 512MB|PATRIOT 2x1GB 800Mhz CL.4|
Kako vključiti 3 monitorje na eno grafično?
152282 (1778) Brane2
Potrjene specifikacije Radeonov HD 5700 (strani: 1 2 )
7610320 (7463) M-XXXX
ram za amd64
161800 (1528) Fizikalko
Nvidia det 52.14 (še vedno beta), FX končno konkurenčen
71626 (1382) Grey
Zakaj ISDN, če hočem ADSL ???
Oddelek: Omrežja in internet
92151 (1999) Bx
