Forum » Pomoč in nasveti » T2 težave
T2 težave
1024 ::
Zdravo!
Od kar sem prešaltal na T2 imam strašne probleme z internetom. Prej sem imel siol in ni blo problemov. Enako hitra linija kot prej - 1mbit. T2 pravi da je vse ok, čeprav ni!
ping google.com -t
Pinging google.com [64.233.187.99] with 32 bytes of data:
Request timed out.
Reply from 64.233.187.99: bytes=32 time=946ms TTL=235
Reply from 64.233.187.99: bytes=32 time=978ms TTL=235
Request timed out.
Request timed out.
Reply from 64.233.187.99: bytes=32 time=858ms TTL=235
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 64.233.187.99: bytes=32 time=1052ms TTL=235
Reply from 64.233.187.99: bytes=32 time=1024ms TTL=235
Reply from 64.233.187.99: bytes=32 time=1039ms TTL=235
Reply from 64.233.187.99: bytes=32 time=1017ms TTL=235
Request timed out.
Request timed out.
Reply from 64.233.187.99: bytes=32 time=986ms TTL=235
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 64.233.187.99: bytes=32 time=870ms TTL=235
Request timed out.
Request timed out.
Reply from 64.233.187.99: bytes=32 time=844ms TTL=235
Reply from 64.233.187.99: bytes=32 time=887ms TTL=235
Reply from 64.233.187.99: bytes=32 time=912ms TTL=235
Reply from 64.233.187.99: bytes=32 time=972ms TTL=235
Reply from 64.233.187.99: bytes=32 time=992ms TTL=235
Reply from 64.233.187.99: bytes=32 time=1003ms TTL=235
Reply from 64.233.187.99: bytes=32 time=1011ms TTL=235
Reply from 64.233.187.99: bytes=32 time=1055ms TTL=235
Reply from 64.233.187.99: bytes=32 time=1034ms TTL=235
Request timed out.
Reply from 64.233.187.99: bytes=32 time=970ms TTL=235
Reply from 64.233.187.99: bytes=32 time=987ms TTL=235
Request timed out.
Reply from 64.233.187.99: bytes=32 time=696ms TTL=235
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 64.233.187.99: bytes=32 time=904ms TTL=235
Reply from 64.233.187.99: bytes=32 time=914ms TTL=235
Reply from 64.233.187.99: bytes=32 time=969ms TTL=235
Request timed out.
Reply from 64.233.187.99: bytes=32 time=829ms TTL=235
Reply from 64.233.187.99: bytes=32 time=676ms TTL=235
Reply from 64.233.187.99: bytes=32 time=715ms TTL=235
Request timed out.
Reply from 64.233.187.99: bytes=32 time=922ms TTL=235
Request timed out.
Reply from 64.233.187.99: bytes=32 time=1118ms TTL=235
Request timed out.
Request timed out.
Reply from 64.233.187.99: bytes=32 time=1012ms TTL=235
Request timed out.
Reply from 64.233.187.99: bytes=32 time=724ms TTL=235
Reply from 64.233.187.99: bytes=32 time=780ms TTL=235
Reply from 64.233.187.99: bytes=32 time=805ms TTL=235
Reply from 64.233.187.99: bytes=32 time=841ms TTL=235
Request timed out.
Reply from 64.233.187.99: bytes=32 time=1048ms TTL=235
Reply from 64.233.187.99: bytes=32 time=1043ms TTL=235
Request timed out.
Reply from 64.233.187.99: bytes=32 time=796ms TTL=235
Request timed out.
Reply from 64.233.187.99: bytes=32 time=998ms TTL=235
Reply from 64.233.187.99: bytes=32 time=1036ms TTL=235
Reply from 64.233.187.99: bytes=32 time=1010ms TTL=235
Reply from 64.233.187.99: bytes=32 time=1009ms TTL=235
Reply from 64.233.187.99: bytes=32 time=1065ms TTL=235
Request timed out.
Reply from 64.233.187.99: bytes=32 time=838ms TTL=235
Reply from 64.233.187.99: bytes=32 time=861ms TTL=235
Reply from 64.233.187.99: bytes=32 time=885ms TTL=235
Reply from 64.233.187.99: bytes=32 time=924ms TTL=235
Reply from 64.233.187.99: bytes=32 time=974ms TTL=235
Request timed out.
Reply from 64.233.187.99: bytes=32 time=674ms TTL=235
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 64.233.187.99: bytes=32 time=1089ms TTL=235
Reply from 64.233.187.99: bytes=32 time=1049ms TTL=235
Reply from 64.233.187.99: bytes=32 time=1022ms TTL=235
Request timed out.
Reply from 64.233.187.99: bytes=32 time=874ms TTL=235
Request timed out.
Request timed out.
Reply from 64.233.187.99: bytes=32 time=710ms TTL=235
Request timed out.
Reply from 64.233.187.99: bytes=32 time=920ms TTL=235
Reply from 64.233.187.99: bytes=32 time=950ms TTL=235
Reply from 64.233.187.99: bytes=32 time=989ms TTL=235
Reply from 64.233.187.99: bytes=32 time=1029ms TTL=235
Reply from 64.233.187.99: bytes=32 time=1018ms TTL=235
Request timed out.
Reply from 64.233.187.99: bytes=32 time=740ms TTL=235
Request timed out.
Reply from 64.233.187.99: bytes=32 time=155ms TTL=235 !!!!!!!!!!! za trenutek normalno
Reply from 64.233.187.99: bytes=32 time=160ms TTL=235
Reply from 64.233.187.99: bytes=32 time=156ms TTL=235
Reply from 64.233.187.99: bytes=32 time=163ms TTL=235
Reply from 64.233.187.99: bytes=32 time=154ms TTL=235
Reply from 64.233.187.99: bytes=32 time=168ms TTL=235
Reply from 64.233.187.99: bytes=32 time=726ms TTL=235
Reply from 64.233.187.99: bytes=32 time=1074ms TTL=235
Request timed out.
Reply from 64.233.187.99: bytes=32 time=1063ms TTL=235
Request timed out.
Reply from 64.233.187.99: bytes=32 time=738ms TTL=235
Reply from 64.233.187.99: bytes=32 time=777ms TTL=235
Reply from 64.233.187.99: bytes=32 time=816ms TTL=235
Reply from 64.233.187.99: bytes=32 time=840ms TTL=235
Reply from 64.233.187.99: bytes=32 time=879ms TTL=235
Request timed out.
Request timed out.
Ping statistics for 64.233.187.99:
Packets: Sent = 171, Received = 123, Lost = 48 (28% loss),
Approximate round trip times in milli-seconds:
Minimum = 154ms, Maximum = 1118ms, Average = 679ms
Control-C
^C
ping google.com -t
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Control-C
^C
Fish knows everything.
c0dehunter ::
Torej je problem. Pošlji jim ta log.
Ali pa je z tvojim računalnikom nekaj narobe, oziroma ti je programska oprema nekaj zjeb4la.
I do not agree with what you have to say,
but I'll defend to the death your right to say it.
blackbfm ::
kabli, router, modem, operacijski sistem, kabel/wireless..vse to vpliva. Potem pa testiraj enega po enega da vidiš kje je problem. Mogoče je kakšna žička za zamenjat v omarci.
markk1 ::
direktno na modem priklopi, če imaš slučajno zadaj router, če ne pa teži na HD2 da ti uredijo stvari.
| » | Router zviša ping???Oddelek: Omrežja in internet | 2926 (2037) | bzp |
| » | Razočaran nad T-2 in njihovim supportom =(Oddelek: Omrežja in internet | 2770 (1740) | Wox |
| » | Volja ADSL in Windows XP - problemOddelek: Omrežja in internet | 2452 (2186) | janez5 |
| » | WTF Google dol padu??Oddelek: Omrežja in internet | 1915 (1160) | AndrejS |
| » | Internet dela pocas ko zelva tetraplegik ... kablasi?!?Oddelek: Omrežja in internet | 2378 (2200) | OrlyTM |
