DvD > Avi convert
DvD > Avi convert
juvanjan ::
Dvd bi rad pretvoril v Avi format.
Iskal sem ze na netu vendar razen trial verzij nisem nasel nic uporabnega.
Poznate morda zastonjski pretvornik ali kaj podobnega?
faceonline ::
DL si program AUTOGK
http://www.videohelp.com/tools/AutoGK
D best
dzinks63 ::
  • spremenil: dzinks63 ()
lasse007 ::
Najprej DVD zripaš na trdi disk (VIDEO_TS mapa) z DVD Decrypter.
http://www.dvddecrypter.org.uk/
Potem pa pride na vrsto AutoGK.
http://www.autogk.me.uk/
Dobro si je prebrati Tutorial.
http://www.autogk.me.uk/modules.php?nam...
AutoGK ima tudi Hidden Options, tu je v bistvu za nastavit .autocrop, koliko (črnega) roba ti reže.
1. Play the material in VLC player.
2. While the video is playing, go to Video > Snapshot.
3. Open the snapshot in the picture-editing program. (npr. Adobe Photoshop)
4. Determine exactly how many pixels you have to shave off each of the four sides for a clean-edged picture.
5. In AutoGK's Ctrl-F9 screen, those numbers go into "Forced Cropping" in the lower-left.
6. Check the "Tune Auto crop Parameters" box, and set "Threshold" number (default 34) to 0.
No še po slovensko: V VLC player narediš posnetek (snapshot), potem pa v npr. Adobe Photoshopu zmeriš koliko pikslov je na vseh straneh črnega roba, greš v AutoGK Hidden Options (Ctrl-F9), te številke daš v "Force cropping of", označiš "Tune Auto crop Parameters" in "Threshold" številko nastaviš na 0 (default je 34).
"Predstave s črno magijo in njenim popolnim razkrinkanjem"
(Mihail A. Bulgakov, Mojster in Margareta)
Adobe Premiere Pro vsesorte
Oddelek: Zvok in slika
252651 (1744) jozekuch
DVDRip serij
121652 (1376) asmircar1
DVD v avi file
91609 (1487) sloyoyo
DVD ripanje
51752 (1619) CaqKa
DVD to DIVX/Xvid?
61473 (1382) Hux
