Forum » Strojna oprema » Intel E5000 serija 45nm
dzinks63 ::
"Intel is also planning to launch the Core 2 Duo E5000 family to replace the previous E4000 family in the entry-level market. The first product from the E5000 family will launch in April next year priced at US$133 in 1000-unit quantities."
"Missing from the latest Intel launch update summary is the Core 2 Duo E5000 series, low-end desktop chips that succeed today's E4000 line-up and which are expected to arrive in April. They're likely to contain just 3MB of L2 and operate on a 1066MHz FSB, putting them under the current 4MB L2, 65nm Core 2 Duo E6000 range."
Še se bo uživalo pri navijanju, saj 4GHz+ ne bo problem.
- spremenil: dzinks63 ()
| » | Težava pri menjavi CPUOddelek: Pomoč in nasveti | 2356 (1879) | spoly24 |
| » | Duo vs. QuadOddelek: Kaj kupiti | 3857 (2010) | st0jko |
| » | Pocen komp za družinske potrebeOddelek: Kaj kupiti | 2310 (1813) | ReBi |
| » | Rabim nasvet glede plate, rama in procesorjaOddelek: Kaj kupiti | 1541 (1341) | kmetek |
| » | Kritični popravki Intelovih procesorjev (strani: 1 2 )Oddelek: Novice / Varnost | 9193 (6767) | Vlady |
