Intel E5000 serija 45nm
dzinks63 ::
:)) Za april obljubljajo zamenjavo za serijo E4000 z novejšo iz serije penryn.
"Intel is also planning to launch the Core 2 Duo E5000 family to replace the previous E4000 family in the entry-level market. The first product from the E5000 family will launch in April next year priced at US$133 in 1000-unit quantities."
"Missing from the latest Intel launch update summary is the Core 2 Duo E5000 series, low-end desktop chips that succeed today's E4000 line-up and which are expected to arrive in April. They're likely to contain just 3MB of L2 and operate on a 1066MHz FSB, putting them under the current 4MB L2, 65nm Core 2 Duo E6000 range."
Še se bo uživalo pri navijanju, saj 4GHz+ ne bo problem.
  • spremenil: dzinks63 ()
Težava pri menjavi CPU
222356 (1879) spoly24
Duo vs. Quad
393857 (2010) st0jko
Pocen komp za družinske potrebe
172310 (1813) ReBi
Rabim nasvet glede plate, rama in procesorja
101541 (1341) kmetek
Kritični popravki Intelovih procesorjev (strani: 1 2 )
Oddelek: Novice / Varnost
629193 (6767) Vlady
