GeForce 8800GT
GeForce 8800GT
2 / 36
LazyAss ::
uvozniki
To mi že dosti pove zakaj ''2950 ne more zravn'' :\
Pita majmunic mamu : zasto smo mi ovako ruzni ? Mama ga tjesi : budi sine sretan da ovako izgledamo, da samo vidis onog koji cita ovo kakav je !!! :PPP
nekikr ::
Ja, glede na to da dobim oboje, lahko rečem da ne pride zraven (price-performance-wise).
Tr0n ::
Potem pa objavi kak test, ce bos res dobil zadevo.
nekikr ::
Zaradi NDA ne smem objaviti česarkoli. Bo pa objavljen popolni test 29ga tudi na Slo-techu (ane Alien3001 :).
Tr0n ::
Oh, c'mon! ;)
Lahko privat. I swear I won't tell. :)
snajper_SLO ::
Samo zdaj, če to drži pa je vprašanje !
~Q6600 G0 + Mugen ~ ASUS P5KC ~ Crucial 2x1GB D9~
~XFX 8800GTX ~ Logitech G15 ~ MX518 ~ LG 22" Wide~
~Antec P182 EU ~ Logitech X-230 ~ X-Ray Thunder 8~
Tr0n ::
Hmm. To je kr neqi. Want some real tests.
nekikr ::
Cca. 5% boljša od tega testa bo. Najbrž zaradi gonilnikov. Tega itaq nisem rekel. :)
Xtra ::
Nvidia has send out a notice to their AICs making clear to them not to market the new GeForce 8800 GTS 640MB as a card featuring 112 SPs although this should be quite a good selling point. Instead, card partners can brand the card as special edition or OC edition ie. GeForce 8800 GTS OC Edition. The new 112 SP 8800 GTS will still work fine with the 96 SP 8800 GTS in SLI configuration. Nvidia stress that they will not offer 112 SP 8800 GTS in 320MB memory configurations.
Tko bo, pa nč drgač :)
Za teste pa se mal počakat.
Xtra ::
nekikr: Am, kko pa veš.Sm nov na forumu, pa te ne poznam lihk:) ...maš kak podjetje k grafe prodaja?
Drgač pa tistih 5% jo lpo blizu GTX pomakne:))
  • spremenil: Xtra ()
steev ::
Tr0n: Hmm. To je kr neqi. Want some real tests.
Daj plis povej samo ali je boljsa ali slabsa kot ta tu na teh slikah. Je boljsa od GTS 640?
cnZz ::
Baje bo bolsa in cenejsa...
AMD X2 64 5000+@2800 | ASUS M2N-SLI Deluxe |
OCZ XTC Cooler 2gb DDR2 800mhz | ASUS EAX1950Pro 256mb |
steev ::
Ta baje smo ze vsi slisal.
TOP ::
Ja to (baje) smo že velikokrat slišali,kaj bo v resnici pa nobeden ne ve.Vemo samo,da bo to okrnjena različica GTS ki bo imela odlične preformanse.
Xtra ::
Težko rečeš okrnjena GTS, če se to približuje GTX-u:))
TOP ::
Ja spet je beseda (če se) in smo spet tam.Bolje je malo še počakat pa da vidimo kaj bo.
Xtra ::
:)) smehi:))
Tilen ::
8800GT bo odlična zamenjava za 7900GS. >:D
AapocalypseE ::
Tilen, pa nisi ti mel tolko proti novim grafičnim karticam 8800GTS, GTX, 2900XT kak je to porazno, a zdaj pa si boš nabavil GT :D počakaj še, ne bodi tako hiter >:D
Tilen ::
Sem še vedno istega mnenja.
Men samo cena ne odgovarja glede na performance. DX10 pa tako ali tako ne bom uporabljal, glede na to da uporabljam win 2003. DX9 performance pa nikoli ni bil vprašljiv. GT bo pa cenejši ter boljši. Get it? Pa še to me vrjetno ne bi prepričalo, če si pred kratkim ne bi nabavil 245B. Zdaj pa enostavno rabim eno ugodno rešitev. 8800GT is way to go ;)
  • spremenil: Tilen ()
Zheegec ::
Nekikr: Sploh ne vem o čem govoriš ?!
Anyway, treba bo potrpet pa počakat na teste, lahko da je boljša, ali pa slabša kot na teh grafih. Takle graf (še boljši!), lahko naredi vsakdo, ki ima 5min časa.
Vemo pa to, da bo najbrž imela dober OC potencial - tudi če bo počasnejša od GTS, zna biti vseeno boljši nakup za tech-freake 8-)
Janez Janša, 29.04.2014
nekikr ::
Alien3001, a bi jo rad dobil al ne? :D
steev ::
Ja on jo bo prvi dobil oz. vsaj stestiral. Big Bang ce se ne motim? Predvidevam ker si veliko debatiral na temo prenosnikov (dell 6400, pa tale k je zej na jumbo).
PINki ::
men gre moja gts na 700, shaderji okol 1550 tm nekje za ramcke pa nevem ka je zmankal cajta, sam itak use se zmer furam na stock ;)
Tr0n ::
Koliko se pa 256-bit memory interface pri 8800 GT pozna vs. 320-bit 8800 GTS?
kixs ::
Ne bi rekel, da grozno veliko.
Banke so po 64MB in vsaka taka banka ima 64bit povezavo. Torej, 256MB verzija ima 256bit (4x64). 320MB pa 5x64=320bit.
640MB verzija ima pa banke po 128MB in spet 64bit vsaka. 5x64=320bit
786MB GTX pa 6x64=384bit
  • spremenil: kixs ()
Tr0n ::
Kaj pa 8800 GT 512 MB verzija? :)
macgajver ::
Men je to ful smešn da so šli nazaj na 256bit vodilo pustil bi tko kot je blo če se jo bo dalo full navijat potem te bo pa vodilo bremzal vsaj pomoje. Mogoče pa ne treba bo počakat kakšen bolj konkreten test.
512mb bo prov prišlo pri višjih resolucijah.
tenstan krompir je pa zakon
Senitel ::
Zakaj misliš, da so šli "nazaj"? >:D
kixs ::
Tr0n:
sej ti pravim, enako kot vecje verzije. 4 banke po 128MB = 512MB, kar se tice sirine vodila, je pa 4x64=256bit.
Nic niso sli nazaj. RAM banke imajo pri vseh verzijah 64bit povezavo. Potem je odvisno samo koliko je teh bank. Pri GTX jih je 6, zato je 384bit.
Kako se bo poznalo to pri uporabi, je pa odvisno kako so te banke med seboj povezane in kako se uporablja paralelizem (podobno kot dual-channel na maticnih).
Xtra ::
Se mal..ne morm čakat:))
Xtra ::
Ste slišal za ATI-jeve grafe?Ne bo nobenga 2950 ampak 3xxx.Hočjo se izognt unim črkam odzat k povejo preformans(XT,XTX, PRO, GT).
Pesimist ::
Meni se se vedno zdi dosti prevec 250€ za neko graficno. Mislim da se dozaj nisem dal vec kot 50k za graficno.
Je pa tudi res da je ta spas vedno drazji... :\
  • spremenilo: Pesimist ()
blazius ::
torej 8800GT pride ven 29. ta mesec, kdaj pa tanova 8800GTS?
GrimReaper ::
Mesec kasneje, 29. november.
Xtra ::
Mislim, da se GTS umika:\ , ne?
Mirč ::
in cena koliko bo kakih 200-250€
kakšne bodo specifikacije napram 8800gts 320mb
Davids84 ::
Geforce 8800 GT doesn't do DirectX 10.1
Written by Fuad Abazovic
Friday, 05 October 2007 09:33
No support for Shader model 4.1
Documents seen by Fudzilla indicates that G92/D8P aka the Geforce 8800 GT is not Shader model 4.1 compatible. It can mean one of two things, one, that Nvidia doesn't want release the information or two, simply that this chip doesn't have support for Shader model 4.1 and DirectX 10.1.
This comes as an interesting surprise as we know that the RV670 aka the Radeon HD 2950 series will support Shader model 4.1 and DirectX 10.1.
We will ask around and try to find out if this is the case, but this would be a big setback for Nvidia, at least when it comes to feature tick boxes on upcoming games.
LazyAss ::
@nekikr :
Price/performance se bistveno bolj splača 8800GT. Edina trgovina, ki bo to kartico imela na zalogi s primerno količino pa je Big Bang (!). Radeon 2950 ne pride blizu ;)
Vrjetno ne dobiš nič od tega in nimaš nobenih testov glede na to da 2950 ne bomo videli NIKOLI ....
Povzetek: lahko to si rečem samo to, da bi lahko zelo uspel na tržnici, kjer gredo bučke veliko bolj v promet kot tukaj :\
Mirč ::
8800 GT: 112sp(1500MHz), 600/1800MHz, 256-bit, 512MB
8800 GTS .96sp(1200MHz), 500/1600MHz, 302-bit, 320MB
2900pro: 320sp(600???zakaj tako malo),600/1600Mhz,512bit,512mb
vse v istem rangu cenovnem
torej čeprav razumem ima nvidia prednost v hitrosti shaderjev in nič druga
Xtra ::
Naslpošen preformans se mi zdi pri njej bol.Mislim, da ima ATI samo večjo prepustnost.Mam prou?:)
kmxkmx ::
Jaz res nevem kaj eni govorite (nekikr) da je 8800 gt price performance boljša od atijevega novega izdelka, če sploh še ni ne enega ne drugega na trgu. Take izjave lahko pridejo samo iz ust kakih fanboyev.
Ker sploh še ni kakih uradnih testov (pa še tem jaz ne verjamem najbolj, ker se razlikujejo od strani do strani), so vse te izjave kar na pamet.
Tako da lepo počakat do izida, Pa pol komentirat performansih!
cnZz ::
lazy ass...
ce mene prasas bo 8800gt zagotovo imel 4.1 shader in dx 10.1 (vsaj zagotovo če bo imel ati to v novih karticah) pa mogoce nvidia se zvisa proc pri novem gtju glede na atija (ampak to so spet samo govorice)
macgajver ::
Loool shader 4.1 in dx10.1 če še shade4 in dx10 niso ornk uporabil
Zheegec ::
LazyAss: Motiš se >:D
cnZz ::
yea right macgajver...
8500 8600 8800gts/gtx/ultra 2900pro/xt/xtx mogoče še kakšna več ki imajo to notri...
GrimReaper ::
Niso ornk uporabil je mislil v igrah, kolker vem je samo 5 DX10 iger, pa še to za 2 rabiš DX10 popravek.
Tr0n ::
Heh, BigBang pravi, da 8800 GT pred koncem novembra verjetno ne bo na zalogi.
nekikr ::
Dj mi prosim povej s kom si govoril.
Na zalogi pa bo definitivno 29ga Oktobra. Mogoče ne ob 9:00 zjutraj, ampak tekom dneva pa 100%.
  • spremenil: nekikr ()
Tr0n ::
Sebastjan pise v mailu. :)
2 / 36
Grafična kartica?! (strani: 1 2 )
6010028 (8870) Meizu
Grafika - a se splača? (strani: 1 2 )
526213 (5205) tilinho20
Radeon 3870 VS GeForce 8800GT (strani: 1 2 3 )
1289989 (9076) JamesBond
GeForce 8800 GT ali GTS ali ?
232250 (2250) LordPero
GeForce 8800 GT uradno predstavljena (strani: 1 2 3 4 )
18815448 (15448) PrimozR
