GeForce 8800GT
GeForce 8800GT
26 / 36
Wofk ::
256MB je dovolj...
...za 1280x1024 brez AA in AF...
...za igre stare 1 leto in vec >:D :)
Horsechoker ::
Double Lifetime Warranty: XFX�s double lifetime warranty program provides lifetime warranty coverage to the original purchaser of the XXX graphics card, as well as the card�s second owner, providing comprehensive warranty coverage to both users. In order to activate the double lifetime warranty, both users must register their card with XFX.
Enthusiasts will also be glad to know that XFX�s warranty isn�t voided if you make modifications to your card, say for instance if you swap out the stock cooler for a more powerful unit, or step up to liquid cooling. As long as you don�t physically damage the card in the process of the upgrade (say for instance, you break off a capacitor), you won�t void the XFX warranty.
To ti je podjetje8-) (a kaj ko tukaj to verjetno "ne velja")
But I don't want to be dead. I want to be alive. Or a cowboy.
dzinks63 ::
:)) >256MB je dovolj... ...za 1280x1024 brez AA in AF...
Tako je vse skupaj postavljeno. Saj kartica za cca 180-200€ je tudi namenjena takim nastavitvam. Za kaj več so pač na voljo boljše in dražje kartice. In če je kdo mislil, da bo za 200€ lahko igral vse na full v visokih resolucijah in high detaljih, se je pač zmotil. Trenutno pač manjka uiber zmogljiva grafična za 500€, ket to trenutno eno leto stara 8800GTX pač ni. Bo treba počakat do februarja , da se predstavi nova G9E.
Wofk ::
draga bo tale kartica za svoj performence
Zheegec ::
Dokopal sem se do par 8800GT od Gigabyte 8-)
Mater jih je težko dobiti >:D
Janez Janša, 29.04.2014
cole-22 ::
Horsechoker ::
Bi znal pasti kak primerjalni test (VF1000 npr)? ;)
TomoSlo ::
Bravo Cole! Si želimo še več slik. Mogoče kakšno kako zgleda v ohišjU,k imaš infinitija zraven..8-)
a gre komu sploh ram cez 1050??
Frame ::
Fantje na temo NEW 8800GTS 512MB.
Kertice so tukaj 100%!
Prodaja se začne 12.12.2007 po 16h.
NDA od Nvidie pač.
Ampak to je 100%,namreč kartice so že na zalogi.
May The Force Be With You!!!!
kotnikd3 ::
cole-22
pol meniš, da se splača kupt Accellero S1 ???
Na eni od slik (na oc-lab2) maš na grafi čist desno nalimane neke modre hladilnike. Tega ne dobiš zraven, ne?
Keri hladilniki pa so to? Navadni?
cole-22 ::
Ja a se ti ne zdi, da se splača kupit, če so temp. padle za 25+ stopinj v loadu?
Modrih hladilnikov ne dobiš zraven.
IVo ::
Men gre ram na 1080 (stabilno). Pa ne me spraševat kaj pomeni stabilno k mi najeda
ce se ne motim mas zdej vodno?
kok je slo na zraku?
IVo ::
Sam GPU je pod vodo, rami so na zraku aka. mam en vent k piha na njih...
Turtle ::
BFG GTS se prodajajo že od prejšnga torka :)
Pesimist ::
for how muchos?
Ma$terM|nd ::
Sem že oddal oglas v Male oglase ampak vseeno če ma kdo odvečen original cooler od BFG 8800gt in je po možnosti še iz okolice MB ga odkupim. mail
GTS ima svojo temo, tko da preselte se tja in ne smetite tukaj.
hvala.
Horsechoker ::
Pri novih karticah ventilator ne bo toliko nadležen. Bo večji (za 1 cm) in se bo počasneje vrtel. Razlika je pa 2,3 stopinje v prid slednjemu( s tem, da sta oba na100% in da je ta v primerjavi z manjšim neslišen).
cole-22 ::
>:D
Mirč ::
XpertVision 8800GT 512MB
kako se kaj obnese ta grafika
Frame ::
Sem že objavil pod temo 8800GTS 512MB.
PA še tukaj da malo predebatiramo:
Evo fantje prvi primerki 8800GTS.
Zadeva se navije ko nora na tovarniškem hladilniku.
http://www.xtremesystems.org/forums/sho...
Kot sm ze reku, nehite smetit z GTS tuki.
damjanll ::
Mirc: XpertVision 8800GT 512MB, kako se kaj obnese ta grafika
Danes sem nabavu Xpertvision 8800 GT v JAE za 237 eur.
Nima stock nvidia coolerja ampak je dual slot resitev ki se izkaze kot dokaj tiha pa hladi tudi super. Temperatura: idle: 53, load: 63
3DMark06: 10100 (C2D E6550, Vista 32)
Navijal pa se nisem, pa najbrz tudi ne bom ker se mi to ne da, dela kul tako ;)
btw a xpertvision == palit?
  • spremenilo: damjanll ()
Mirč ::
jap v jae je ugodna
batista ::
Hmmm nikjer ne najdem te grafe na JAE ceniku. Nekam malo pik v 3dmark 06 za tale xpertvision. Tolk dobim jest na e4300 in 8800gts320mb, res da je navita ampak vseeno bi ti mogu dobit več na 8800gt.
cole-22 ::
Za njegov sistem je normalen score.
CPU in GPU nista navita
Vista
Slab score
kitzbrado ::
Z novimi karticami mislis na GTS ali bodo zamenjali tip stock hladilnika na GT?
Horsechoker ::
Zamenjali so/bodo stock hladilnik za GT.
damjanll ::
batista: Hmmm nikjer ne najdem te grafe na JAE ceniku.
Drzi, JAE te kartice se vedno nima na spletnem ceniku, jaz sem narocil sicer Leadtek 8800GT, pa so rekli da jo dobijo sele naslednji teden ampak da lahko dobim xpertvision takoj pa za isto ceno, seveda sem jo vzel, sedaj ko pa vidim da ima se celo boljsi cooler pa sem se tolko bolj zadovoljen ;)
Sem pa opazil da je kvaliteta TV-Outa preko s-video kabla malenkost slabsa kot pri perjsnji (gigabyte 8600gts passive).
Pa se nekaj, ob rebootu mi sistem 2x nadlezno zapiska, tega prej ni bilo, pa se sprasujem ce imam mogoce presvoh napajalnik al kej.. imam pa Zalman 400W ZM400B-APS. Ob prvem bootu, torej ce ugasnem in prizgem pa nic ne piska, cudno...
batista: Nekam malo pik v 3dmark 06 za tale xpertvision. Tolk dobim jest na e4300 in 8800gts320mb, res da je navita ampak vseeno bi ti mogu dobit več na 8800gt.
Ok, pa se par 3dmark06 testov:
cpu: E6550, mb:ga-p35-ds3, mem: 4gb@800 ddr2
stock freq: cpu 2333 gcore 600 gmem 900
Vista: 10100
XP: 10343
OC: cpu: 2494 gcore: 702 gmem: 1008
Vista: 11009
XP: 11149
So to v redu rezultati al kej ne klapa?
Horsechoker ::
Shader nisi navil?
Danes sem lepo na montiral VF1000 in moram reči, da deluje odlično. ŽE samo v idlu je razlika 10+ stopinj, v loadu pa temp ne preseže 50, kljub temu da sem jo uspel še bolj naviti. Bi pa izpostavil, da je nvidia (ali kdo drug, ki je odgovoren za to) pretiravala z termalno pasto, BIG TIME.
damjanll ::
> Horsechoker: Shader nisi navil?
Navijal sem kar z nvidia ntune, sedaj sem pogledal z rivatunerjem in kakor vidim ce dam gpu core na 702 postavi shader na 1755.
Veron ::
xpertvision so na voljo v Jae, učer je pršlo 20kosov ;) navali narode :D
matija14 ::
Sem nardil slabo potezo ker sm pri mimovrste=) naročil danes Leadtek WinFast PX8800GT 512MB za 240€?:\ :\ :\ :\ :\
Veron ::
nup, dobra "poteza". Sej je vseeno kje jo kupiš, važno da jo dobiš ;)
matija14 ::
OK, hvala, bom bolj brezskrbno pričakal paket.:)) :))
Itak so od različnih proizvajalcev(Gainward, XFX..) podobno dobre, al ker sem glih najcenejšo vzel je kej slabša?
Shegevara ::
komaj čakam 8500GT 1GB >:D
Yaqwsx ::
ko da bi v 386tko dal 1gb rama
schaf ::
Vceraj sem v AGT prevzel naroceno blago ter izvedel, da imajo na zalogi se nekaj XFX, BFG 8800GT (Extreme). Ce kdo se isce, naj poklice tja.
Pesimist ::
Kaj tisto z jae je bol pod mizo prodaja? Jaz se pred letom ali dva tudi naroco eno graficno pri Jae, in tudi je bl Leadtek poceni, katerega seveda niso meli in so mi zato dragega asusa za isto ceno ponudli. Katerega takrat tudi nisem dobo ker so rekli da je bla zadna in kao pokvarjena. Oni to prej testirajo al kaj?
Anyway to se zdaj cuje cisto isto kot moja fora le da jo je on res dobo od Jae. Drugace pam kam koli gledam je ta Sonic karta z tem bolsim coolerjem 270+ €.
mesoreznica ::
Tudi mene vleče tale 8800 GT pri JAE. A je AMD X2 4200+ dovolj močen da bo izkoristil 8800 GT? ATI odpade, poln kufer ga imam.
Gigabyte UD3P, E8500 @ 4.5 GHz , HD4870-X2, 4GB ram (Xtreeme Dark),
WD Velociraptor, LC Legion-X
Pesimist ::
Karta pri Jae je 242€. Ampak je reko da letos nix vec teh z supercoolerom.
GrimReaper ::
Vzemi HD3850 256MB za 160€ in pozabi na 8800GT, nima smisla dajat na tak procesor.
Prelox ::
A mogoč kdo ve ka bi blo narobe da mi v Cod4 izvrže sam povprečno 60 FPS al dam vse na low al pa vse na high.
Fps max na 250, na novo instalirani winsi.
Asus M2N-E
AMD 3800+ X2
BFG 8800GT OC2
1.5 Gb ramov
winows Xp 32
The_hammer ::
Zvočna te jebe.
Intel E6420@2950, 7900 gto, 2gb,seagate baracuda 160,Keyboard G11,
Mouse mx518,Mouse surface Razer eXactMat, Speed link Medusa 5.1,
Enermax liberty 500W
Horsechoker ::
Tisti ki hočete še malo iztisniti iz svoje grafe obenem pa nočete delati fizičnega voltmoda priporočam flešanje biosa. Softwersko (s pomočjo NiBiTora) se lahko voltaža dvigne na 1.1 (privzeta je 1.05V). Pri meni in pri večini je razlika kar opazna.
damjanll ::
Prelox: najbrz imas LCD monitor in vklopljen vsync?
kotnikd3 ::
Horsechocker:
a lahko narediš krajši vodič glede višanja voltaže pri Nibitorju? tnX
(greš pod voltages, VID mode, kaj pol?!?)
26 / 36
Grafična kartica?! (strani: 1 2 )
609984 (8826) Meizu
Grafika - a se splača? (strani: 1 2 )
526184 (5176) tilinho20
Radeon 3870 VS GeForce 8800GT (strani: 1 2 3 )
1289941 (9028) JamesBond
GeForce 8800 GT ali GTS ali ?
232232 (2232) LordPero
GeForce 8800 GT uradno predstavljena (strani: 1 2 3 4 )
18815311 (15311) PrimozR
