Forum » Igre » Poganjanje na 1 jedru
jest10 ::
Zanima me, kateri ukaz je potrebno dati v bljižnico do igre, da le ta teče na enem jedru? Ker ena starejša igra ne prenaša dobro dvojedernika
Vsakokratno nastavljanje v Task managerju pa nekako ne pride v upoštev.
- spremenilo: jest10 ()
Tilen ::
A ta nastavitev v task managerju [afinity] ni trajna?
3. Use an affinity masking tool such as
ImageCFG (http://www.robpol86.com/Pages/imagecfg.... for instructions on how to use). Backup your .exe before using this program. Imagecfg has a problem with some directories with spaces in them, so its easiest to stick it in the folder with the *.exe file you want to change. Then use the command you need (knowledge of the DOS prompt is a must ):
imagecfg -a 0x1 game.exe for core 1
imagecfg -a 0x2 game.exe for core 2
Izvzeto iz: Dual Core - Gaming Fix Guide
- spremenil: Tilen ()
McMallar ::
Mislim da affinity ni trajen. Jaz sem si pomagal s programom runfirst.exe. Deluje. Runfirst.exe
Heavy ::
Jaz sem tudi imel težave z igrami na dual core procesorju, a po namestitvi AMDjevega gonilnika deluje vse np.
| ⊘ | Burnout Paradise The Ultimate BOX in DIRT 2 problemOddelek: Igre | 1179 (1154) | Rotaidal |
| » | zamenjava AMD Athlon 64 za x2, ali bo delaloOddelek: Kaj kupiti | 2131 (1464) | ender |
| » | Dual core and games..Oddelek: Pomoč in nasveti | 1538 (1315) | StajercSSS |
| » | Mafia - pomoč prosimOddelek: Igre | 1754 (1388) | Cowboy6 |
| » | Kako zagnati DOS igro v XPjihOddelek: Igre | 2325 (2052) | Kaboom |
