Forum » Hlajenje in modifikacije » Price Of radiator
Price Of radiator
Hunter ::
Hi Segi, The basic radiator WITHOUT fan's or shrouds is $27.00 US dollars. I would only be guessing on shipping cost, but if you provide me the CITY and ZIP where you live I can find out the shipping cost.
Dober Dan
Dober Dan
- spremenilo: Hunter ()
segi ::
Thank you!
OK i will try to give you my address.
I live in slowenia, zip code is 2000
How long must i wait if you send this radiator tomorow.
Please tell me price of shipping:D
My english is very bad, isn't it?!?!?:8)
Segi podobo na ogled postavi,
ker bolj resnico ljubi kakor hvalo,
zad skrit vsevprek posluša, kaj zijalo
neumno, kaj umetni od nje pravi
- spremenil: segi ()
Hunter ::
Segi, using U.S. postal service it would cost between $17.50-$22.75 dolars to ship. Would arrive in 4-7 days. Total for the radiator and shipping $45.00-$49.00 dolars. NO FANS OR SHROUD.
This is the basic radiator. I would put new hose barbs on it for you. Fan area size 6"x6"x2". Overall size is about 6"x8"x2"
royt ::
to niti ni tako drago. če gledaš...vse skupaj je to okoli 13K. če se ne motim (nekam malo se mi zdi).
je brez ventilatorja, vendar, na sliki se ne vidi, kako bi jih potem gor vrgu.
kar se tiče SHROUD- v slovarju piše to kot mrtvaški prt. mislm...
PS:
segi, ka ga misliš kupiti
aja...segi, ti si bolj nadarjen anglež, kakšna je debelina cevi. taka mora bit, da paše na B&M. pa na kok shladi vodo.
PS:
- spremenil: royt ()
segi ::
Hunter please give me your e-mail address and i will talk with you on mail.
or send me message on my mail click HERE.:D
see you!!:D
Res ga mislim kupiti. Za cevi pa moram pogledat v slovar kako se to vpraša pa še moram vedet kolikšna debelina je na boeingovem bloku!:D
see you!!:D
slon ::
Segi preden naročiš poglej pečko od opel corse l 91 je enaka cena na odpadu do 4k sit.
AMD Ryzen7 5900x & MSI MAG 570x TOMAHAWK
& Asus TUF 3080 & 32 GB 3200MHz@3600MHz
& Samsung 970 Evo plus 1TB & LG 27GL850
segi ::
Misliš da je tisto bolje??
Dami ::
En frend mi je reku da majo v Avto Zanič (en šop z rezervnimi deli tuki v Bistrci) novi grelc od golfa za 7jurjev. Si morm enkrat cajt vzet pa id dol pogledat. Sam težko bo kr sn cele dneve na faksu;(
- spremenil: Dami ()
segi ::
Ja samo kako naj grelec spremenim v radiator.Jaz rabim hladilnik. Dajte malo razložit dečki ker tega šita ne kapiram najbolje.
segi ::
A že kapiram na grelec potem montiram velik ventilator pa je to hladilnik. Samo kaj pa priključki??
slon ::
Odvisno je kake priključke boš rabu.Naprimer 1/2 cole pomeni dobiš medininasto smrekco 1/2 cole in jo prilotaš na te cevi
poglej na ta forum link kjer je HUNTER doma POD imenom DodgeViper .Tam tudi slikovno pokaže kako je on zrihtal priključke.
Lahko rečem da tip naredi izdelek do popolnosti.
- spremenilo: slon ()
segi ::
Ja hvala, kaj pa meniš glede tega da bi raje kupil nek radiator od avta za 7k sit in dal gor ventilator.Meni se skoraj zdi bolj racionalno.
Ali je to tudi boljše?????
VASkO ::
kaj tupis? radiator je radiator, pa ce je od avta ali doma narejen, nekako te razumem, kot da ne ves, o cem govoris, segi.
drugace pa dobis rabljene na odpadu ze zastonj ali kvecjemu za 1000 SIT. Ostalo daj raje za dober blok ali pumpo ali tihe ventilatorje.
segi ::
Ja saj razumem. Na radiator od jugeca alio pa kakega avta dam vente gor pa priključim cevi gor in tako dalje.:D
| » | Katalog radiatorjev evropskih avtomobilov (strani: 1 2 3 4 … 7 8 9 10 )Oddelek: Hlajenje in modifikacije | 75230 (43299) | lufy |
| » | sam bi naredil radiator ...Oddelek: Hlajenje in modifikacije | 2886 (2426) | Karaya 52 |
| » | Hipoteza: "VODNO HLAJENJE" >>>>resnica čakaOddelek: Hlajenje in modifikacije | 2819 (2246) | VASkO |
| » | HladilnikOddelek: Hlajenje in modifikacije | 2036 (1795) | segi |
| » | Water Block/Heater CoreOddelek: Hlajenje in modifikacije | 3129 (2444) | DrSergioDJ |
