Forum » Programska oprema » [KNotes] The KDE Crash Handler
Jst ::
Sem kar veliko uporabljal "nalepke", do danes, ko so se odločili za stavko. Poženem iz KDE_Menija, nato pa dobim KDE Crash Okno.
Pod Backtrace je pa to:
Komu kaj jasno, zakaj mi je zadeva kar iznenada nehala delovati?
System configuration startup check disabled. (no debugging symbols found) Using host libthread_db library "/lib/libthread_db.so.1". (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) [Thread debugging using libthread_db enabled] [New Thread -1236666672 (LWP 4711)] (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) (no debugging symbols found) [KCrash handler] #9 0xb7e56297 in QMapPrivate<QCString, QString>::find () from /opt/kde3/lib/libkcal.so.2 #10 0xb7e55969 in KCal::CustomProperties::nonKDECustomProperty () from /opt/kde3/lib/libkcal.so.2 #11 0xb7e5601b in KCal::CustomProperties::customProperty () from /opt/kde3/lib/libkcal.so.2 #12 0x08076fb7 in KNote::staticMetaObject () #13 0x0806657d in KUniqueApplication::metaObject () #14 0x0806a236 in KUniqueApplication::metaObject () #15 0xb6e243cd in QObject::activate_signal () from /usr/lib/qt3/lib/libqt-mt.so.3 #16 0x0808887e in KNotesResourceManager::staticMetaObject () #17 0x08088f0f in KNotesResourceManager::staticMetaObject () #18 0x0808ad2b in KRES::Resource::metaObject () #19 0x080890f3 in KNotesResourceManager::staticMetaObject () #20 0x08068126 in KUniqueApplication::metaObject () #21 0x08064b6c in QWidget::setUpdatesEnabled () #22 0x080f21c8 in ?? () #23 0x080ab7c0 in ?? () #24 0x080f0d6e in ?? () #25 0xbf8e6024 in ?? () #26 0xb7290ff4 in ?? () from /usr/lib/qt3/lib/libqt-mt.so.3 #27 0x080f0d6e in ?? () #28 0xbf8e5f98 in ?? () #29 0xb70c8d73 in QCString::~QCString () from /usr/lib/qt3/lib/libqt-mt.so.3 #30 0xb74246ed in KUniqueApplication::processDelayed () from /opt/kde3/lib/libkdecore.so.4 #31 0xb745e5c8 in KUniqueApplication::qt_invoke () from /opt/kde3/lib/libkdecore.so.4 #32 0xb6e243cd in QObject::activate_signal () from /usr/lib/qt3/lib/libqt-mt.so.3 #33 0xb715e1ae in QSignal::signal () from /usr/lib/qt3/lib/libqt-mt.so.3 #34 0xb6e40497 in QSignal::activate () from /usr/lib/qt3/lib/libqt-mt.so.3 #35 0xb6e47823 in QSingleShotTimer::event () from /usr/lib/qt3/lib/libqt-mt.so.3 #36 0xb6dc5647 in QApplication::internalNotify () from /usr/lib/qt3/lib/libqt-mt.so.3 #37 0xb6dc64f9 in QApplication::notify () from /usr/lib/qt3/lib/libqt-mt.so.3 #38 0xb74831f2 in KApplication::notify () from /opt/kde3/lib/libkdecore.so.4 #39 0xb6dba663 in QEventLoop::activateTimers () from /usr/lib/qt3/lib/libqt-mt.so.3 #40 0xb6d74bd0 in QEventLoop::processEvents () from /usr/lib/qt3/lib/libqt-mt.so.3 #41 0xb6ddc0e0 in QEventLoop::enterLoop () from /usr/lib/qt3/lib/libqt-mt.so.3 #42 0xb6ddbf76 in QEventLoop::exec () from /usr/lib/qt3/lib/libqt-mt.so.3 #43 0xb6dc500f in QApplication::exec () from /usr/lib/qt3/lib/libqt-mt.so.3 #44 0x08064aa9 in QWidget::setUpdatesEnabled () #45 0xbf8e659c in ?? () #46 0x08093dc3 in _IO_stdin_used () #47 0xbf8e659c in ?? () #48 0x08093dbb in _IO_stdin_used () #49 0x00000000 in ?? ()
| » | Težava Microsoft-Windows-Kernel-Power (strani: 1 2 )Oddelek: Pomoč in nasveti | 10264 (7274) | Anney |
| » | [Code:Blocks, c++] Program ne najde knjižniceOddelek: Programiranje | 1788 (1567) | gtu |
| » | BSOD problemOddelek: Pomoč in nasveti | 2249 (1907) | Oktan |
| » | Windows XP Black screenOddelek: Pomoč in nasveti | 4823 (4563) | Twix |
| » | Google Earth odslej tudi za Linux (strani: 1 2 )Oddelek: Novice / Ostala programska oprema | 9843 (8021) | der_Alte |
