Security Alert
Security Alert
razzor ::
The firewall has blocked internet access to your computer (NetBIOS session) from 217.72.66.176(TCP Port 4327) (tcp flags:S)
A mi lahk kdo pove kaj to pomeni?!?
To mi skos nabija firewall.
ZoneAlarm Pro blocked access to port 139 on your computer
No breach in your security has occurred. Your computer is safe.
What happened?
ZoneAlarm Pro prevented a remote computer from connecting to port 139 on your computer. If you are sharing files on a local network, this connection attempt was probably legitimate network traffic. Port 139 is commonly used by networked Windows computers to enable file sharing and other resource sharing. However, if the traffic that generated this alert came from the Internet rather than a local network, this may have been attack on your computer!
Kdo me napada ?
  • spremenilo: razzor ()
OmegaBlue ::
Nihče te ne napada, večinoma so to samo črvički, ki lazijo po internetu in iščejo kateri genij ima odprt sharing na ven.
razzor ::
aja in kaj pol delajo zakaj hočejo vstopat skozi moja vrata :)
strictom ::
Iz istega razloga kot lopov vstopi v hišo, ki ima na stežaj odprta vrata!
Ti imaš pa nasrečo zaklenjena in še zaščitena.
:D
razzor ::
se pravi da je to lahk trojan al spy ware al virus, in od kje lahk glih nene najde
bluefish ::
ker uporabljaš internet >:D
amigo_no1 ::
ter windows OS .
bluefish ::
sicer pa v večini primerov kontakti in napadi "od zunaj" ne pomenijo, da imaš nameščen spyware, trojance,... Bolj zaskrbljujoče bi bilo, če bi nek neznani program nonstop poskušal kontaktirati navzven.
In btw, OS pri tem skorajda nima veze.
  • spremenil: bluefish ()
Kateri firewall? (strani: 1 2 3 4 5 6 7 8 9 )
413136680 (26167) Qushaak
Varnost
1125030 (6731) techfreak :)
e-mail naslov in SPAM problem
Oddelek: Omrežja in internet
72110 (1944) alef
ZoneAlarm in Apache
81640 (1545) govno
Kako vem da je moj PC varen pred vdori?
Oddelek: Operacijski sistemi
112319 (2026) ABX
