Forum » Kaj kupiti » ocenite prenosnik
ocenite prenosnik
Lamea ::
torej moj prenosnik je ;
ChiliGreen mobilitas M400A
pise sicer model M4A ; )
Star je pa leto pa pol ; )
Zanima me pa kolko naj dam ceno?!HValaaaaaaaaaaaaa.
Chipset: intel 915PM + ICH6-M
Ram: 1G ddr (333)
Display: 15.0" XGA Flat Panel TFT (1024*768)
Video adapter: ATI X700 PCI-E 16X 128MB DDR-DRAM
Disk: 60GB 5400rpm
Optical: 8x Multiformat Dual Layer DVD
Audio: 7.1 Channel High Definition
Pcmcia: One Type-II PCMCIA CardBus PC Card Slot
Interface: Four USB 2.0 Ports
One Mini-IEEE 1394 Port
One External Monitor Port
One Parallel Port (LPT1) Supporting ECP/EPP
One S/PDIF Output Jack
One S-Video-Out Port
One Infrared Transceiver
One Headphone-Out Jack
One Microphone-In Jack
One Line-In Jack
Card reader: Embedded 3-in-1 Card Reader (MS/ SD/ MMC)
Communication: 56K Plug & Play Fax/Modem v.90/92 Compliant
1Gbit PCI-Express Fast Ethernet Card
Power: Full Range AC Adapter 90 W 100~240V,47~63Hz
6 Cell Smart Lithium-Ion Battery Pack, 4.4AH
Additional: pcmcia wireless adapter 802.11G/54Mb
Ram: 1G ddr (333)
Disk: 60GB 5400rpm
One Line-In Jack
La Femme. Think of me sweetly.
- premaknil iz Pomoč in nasveti: gkovac ()
| » | kateri prenosnik od teh dvehOddelek: Kaj kupiti | 1526 (1468) | tomaz- |
| » | Nakup prenosnika - 3 opcijeOddelek: Kaj kupiti | 4392 (2682) | Jackass |
| » | Težava z nakupom prenosnika!Oddelek: Kaj kupiti | 2843 (2297) | samo112 |
| » | Kupujem prenosnik...Oddelek: Kaj kupiti | 2344 (1953) | JIM22 |
| » | Nakup "ultraportable" prenosnikaOddelek: Kaj kupiti | 1827 (1537) | jlpktnst |
