kateri 24" monitor kupiti
Hmm burn-in? Na LCD-ju? Prvič slišim.
To je zato, ker se ne sliši, ampak vidi. ;)
Je res redkost, posebej na novejših LCD.
€uro ::
27'' is the same as the 24'' resolution 1920 x 1200
Kako to zgleda v praksi? So na 27'' (mnogo) večje črke kot na 24'', ali so celo na 27'' bolj "naravne" (tj. lažje je brati/pisati)?
Ne bi rad gledal posamezne piksle na 27'' (nima noben 27'' večjih resolucij). :)
  • spremenilo: €uro ()
€uro ::
Če bo še kdo premleval o tem:
I have the 2707WFP. I did a lot of reading before buying this one, and obviously the "larger" pixel thing was brought up more than once in various forums. I never really understood what they meant, so I went to a Dell store to take a look. To be honest, it's not like I can actually see pixel on my screen and I'm so picky about my screens that I'll wipe off even a single speck of dust.
It's larger, there's a lot of screen estate, and because I work in a home office, I can put this monitor much further back than my previous dual 20" LCD setup. Before I was maybe about 8" away from my 20". Now I'm at almost 17" away from the 2707WFP. That's a huge improvement and less strain on my eyes. And just generally being able to sit further back from the computer has made me less stressed over all and my back doesn't hurt as much.
Watching movies and TV on this thing is great. I can just sit back and enjoy. I highly recommend this monitor to anyone with the desk space, it'll definitely take up a fair amount. And unless you work in an environment where "big pixels" are a no-no, just pretend like you never heard it. It's a great monitor.
jerry2000 ::
Tile "wide gamut" monitorji za smrtnika ki se z Webom ukvarja ravno niso zaradi barv :-( Kdo svetuje dober S-IPS monitor ki ni Wide gamut ampak sRBG?
Jerry and Tom
igor0203 ::
Ima kdo kakšne izkušnje s stenskimi nosilci za LCD monitor? Namen imam kupiti 24" monitor in bi ga dal na steno, nisem pa prepričan če standardni stenski nosilci podpirajo rač. monitorje. Vsi omenjajo nek VESA standard.
Matev ::
tisto kar na 24inčnem pogledaš od blizu
ali povečaš font
tisto je na 27 inčnežu tako veliko da se ti ni treba naprezati
vidiš kot marija
AvtoR ::
Zame ima 24" monitor mogoče že malo majhno piko.
27" je optimum za resolucijo 1920*1200.
Velikost pike je primerljiva s 19" LCD-jem to je okoli 0,3mm.
skrc ::
Smem vprašati koliko in na kakšnem nivoju se z webom ukvarjaš? Ker kolikor je meni znano en kodira, drugi pripravlja grafiko itd.
Drugače ti pa lahko tako povem... vse skupaj glede wide gamuta je en navaden bullshit.
Sam imam HP LP2475W in sem nad njim navdušen. Ti povem s čim se poklicno ukvarjam? Projektant sem.
Menim, da je tole glede wide gamuta eno navadno natolčevanje in plašenje morebitnih kupcev (ali pa tistih, ki se zgolj slinijo ob takem monitorju). Mogoče pa bluzenje tistih, ki se samo ne znajo odločiti kaj točno bi sploh radi imeli?
Fantje, zadnji čas je, da že enkrat nehate bluzit in stvar sprobate. Prišparali si boste kar nekaj živcev, nam pa ne bo treba brati brezveznih postov brez kakršnekoli vsebine. Internet in forumu so postali navadno sranje, odkar ljudje ne znajo več razmišljat s svojo glavo, ampak le nekaj blebetajo zgolj zato da se jih opazi.
ASUS P5Q Deluxe, C2D Q9300, Asus Silent Square EVO
2x2gb Mushkin 1066mhz, BFG Tech geforce 8800GT OC2,
Seagate 500gb 32mb, Mushkin 650W
kmetek ::
Sosed se je razjezil ;)
fizolcek ::
Tast ima HP 2475W in sam tega monitorja ne bi kupil ravno zaradi "wide gamut", tako da očitno, da smo si ljudje različni. Sploh ker mu ne deluje sRBG način, kot recimo Dell u2410, ki ga povrhu še kalibrirajo v tovarni.
jerry2000 ::
web dizajn in programiranje. Rabim ostre črke in prave barve
Jerry and Tom
BlaY0 ::
Za web design pa res ne nucaš "pravih" barv... tisti ki gledajo tvoj web itak nimajo takega monitorja kot ti in ne bodo videli takšnih barv kot ti. Še več lahko pride do tega, da boš izbral barvo, ki je ostali ne bodo videli oziroma jo bodo videli enako kot kakšno drugo barvo.
Za web design rabiš torej tak monitor, ki prevladuje na tržišču oziroma ga ima največ tvojih internetnih "brskačev".
jerry2000 ::
Ja no, recimo. Samo 2001FP pač nima vseh barv, ko RGB premikam tam nad 240 naprej se razlik skoraj ne vidi, predvsem svetlo vijolična (Cyan) je neobčutljiva za razlike.
Rabim pa IPS zaslon, ker bi rad ostrino dobro in vidne kote. In tu je potem problem. Non Wide gamut s S-IPS = ???
Jerry and Tom
Matev ::
jerry2000
kar ti rabiš bo nekaj kar stane 200-150 eur
jerry2000 ::
Malo dvomim...
Jerry and Tom
OZZY ::
mogoče je mislu na kalibrator za monitrje, ki stanejo cc 150-200eurov.
Go with the flow.
zile ::
n Wide gamut s S-IPS = Dell U2410 v sRGB načinu
N-E-O ::
Meni se je pa na Samsung T240 na sredini pojavila črna pika na belem ozadju, oziroma bela pika na črnem ozadju. Verjetno gre za mrtvi piksel - ker do sedaj nisem imel teh izkušenj, me zanima če lahko to kdo potrdi. Kako je tukaj z uveljavljanjem garancije, če gre zgolj za eno mrtvo piko?
Sicer pa na sploh nisem zadovoljen s tem monitorjem. Že po prvem tednu je bil na servisu (je bila čez ves zaslon taka horizontalna rumena črta). Pa tudi utripa mi kot zmešan (prenosnik prek HDMI) ob grafično zahtevnih vsebinah (tega problema še zdaj nisem rešil, ker ga ne znam).
Follow the white rabbit.
Leks ::
Pri monitorjih in garancijah je tako, da določeno število mrtvih pixlov lahko ima in ti ne bodo upoštevali garancije.
Preveri na servisu kako je pri tvojem modelu.
kmetek ::
lol N-E-O: sami izgovori "nisem zadovoljen"....po 1 tednu bi ti ga morali takoj zamenjati....preveri na gar.listu kako imaš s pikami, 1 ni garancija.
N-E-O ::
Kakšni izgovori neki? Vse kar sem napisal drži.
Saj na servisu so rešili prvotni problem (rumena črta na zaslonu). Utripanje zaslona pa je očitno posledica nesporazuma med monitorjem in prenosnikom (oz. njegovo grafično kartico ATI mobility HD2600-> gonilniki). Monitor sicer normalno deluje na ostalih računalnikih, tudi moj prenosnik se "šteka" z drugimi monitorji. Pač se bom moral sprijazniti s tem (mogoče pa ATI problem reši z novimi driverji).
zile ::
Na Qsix so že podražili Dell Ultrasharp U2410 iz 469 na 490€. Očitno gre po poti HPja.
Ga je mogoče že kdo naročil?
Redneck ::
LCD monitorji in TVji imajo (nekateri bolj, drugi manj) tezave z image retention. Plazme imajo birn in, ki je drugacen a naceloma tudi ozdravljiv. Pri LCDjih pomaga, ce so odklopljeni priblizno toliko casa kolikor je bil prikazana staticna slika, ki se je "vzgala". Nasploh pa pri plazmah in LCDjih pomaga, ce se po vec ur predvaja snezenje (slika brez signala) in obstajajo tudi DVDji za to ampak dejansko si je najbolje narediti video, ki se loopa. Tudi plazmo se da tako "odzgati".
Nekater popolnoma, nekatere delno, LCDje pa praviloma v celoti. LCDji imajo vec problemov kot so sprva proizvajalci mislili. Precej LCD TVjev dobi TIR (temporary image retention) kjer mocna slika (predvsem grafike ala meniji ali PC priklop) vztraja se nekaj sekund ali minut. Pri mnogih se to kar nenadoma pojavi po kakem letu uporabe itd...
Skratka LCDji niso tako drasticno bolj zanesljivi od plazem in je bolj smiselno kupovati malo cenejse modele z mislijo na menjavo po kakih 4 letih kot ultra drage, ki prav tako dobijo take tezave, v garanciji jih ne priznavajo....
bluefish ::
Dražje ekrane nas večina kupuje z razlogom. Sploh pa tudi VA matrike niso več tako drage - 22" že za manj kot 300€.
MedusasPath ::
Hmm. Najbrž bom počakal, da pride U2410 v Slovenijo in videl kako bo s cenami. Če bodo vsaj približno podobne tistim v tujini, ga bom vzel.
Meni se je na enem starem LCD monitorju nenadoma pojavila neka razmazana medla packa na zaslonu. Nekaj časa sem mislil, da je samo malo umazan, potem sem se ga pa enkrat lotil temeljito čistit, pa hudič ni šel stran.;) In mi nekaj časa ni bilo jasno, kaj bi to bilo, potem sem pa le pogruntal, da je to "odsev" nekega bolj kontrastnega dela slike, ki sem jo imel za ozadje desktopa. Čez čas je potem tudi izginil.
O.
klemzyZemzy ::
Zdravo,
Pred kratkim sem se odločil za nakup malo večjega monitorja. V ožji izbor sta prišla slednja dva:
http://accessories.us.dell.com/sna/prod...
http://www.akcija.si/izdelek/69950/Moni...
Zanima me katerega mi bolj priporočate, sam se sicer bolj nagibam k dell-u, vendar me vseeno zanima vaše mnenje. Monitor bom uporabljal za programiranje ter gledanje filmov. Sicer nisem zelo zahteven glede nakupa, vendar imam namen monitor uporabljati kar nekaj časa zato mi ni, da bi kupoval najcenjše. Zanima me še ta HDCP zaščita. Povsod mi piše DVI-D z HDCP podporo. Mar to pomeni, da je HDMI nima?
Hvala za odgovore
Lep pozdrav
ddasd ::
kupujem lcd monitor... 24" ali 27" ali kej umes ( tudi z tunnerjem je lahko )
okol 300-360EUR
sicer mi je kolega priporočal http://www.mimovrste.com/artikel/265007... pa so mi nekje rekl da se ne spalča kupit 27" ker ma kao preslabo ločljivost.. ,.. :)
ima kdo kako konkretno idejo kaj se mi najbolj spalča kupt :) imel bi pa rad kvalitetnga
hi
bluefish ::
Finta ločljivosti je ta, da imata tako 24" kot 27" enako ločljivost in je pri slednjem pika večja. Za nekatere je to prednost, za druge slabost - odvisno od uporabe.
Sicer pa je dobro vedeti, kaj boš na njem delal.
Kvaliteta pa je subjektiven pojem - ali se gre za ohišje ali tudi sliko in kvaliteto prikaza.
ddasd ::
kaj bom delal? gledal filme,brskal po netu,... :) verjetn bom kdaj tudi kake igrce igral.. pac to kar se dela normalno :)
nism nek programer al pa desajner,.. :) sm pa ucas igrce igral.. zdj ne vec.. sam nikol ne ves kdaj se bo spet kej igral :)
hi
Matev ::
potem ti 27 inčneže boj priporočam
24 tudi ni slab
a je evdno bolje imeti malce več
(sam imam 24 inčni zaslon - in sem zadovoljen, bo pa moj naslednji 27 inčnež)
SPEEEED ::
Mogoče kdo že poiskusil tega?
http://www.mimovrste.com/artikel/265006...
ddasd ::
torej mi priporocate da kupim http://www.mimovrste.com/artikel/265007... al ima kdo kako bolso idejo, ponudbo, stvar,..
hi
AvtoR ::
Za resno delo tole ni, je preslaba kotna vidljivost.
To pri večjem zaslonu še toliko bolj pride do izraza.
Jaz sem pred dvemi leti nabavil Samsung 275t s S-PVA matriko.
Takrat je stal okroglih 1000€. Ni mi žal niti centa, ki sem ga plačal. Ko se enkrat navadiš na dobro sliko ni več koraka nazaj, se preveč razvadiš. Sam imam konkretno probleme s sliko na prenosnikih. Barve sprane, pa še spreminjajo se ob najmanšem premiku glave...
bluefish ::
Glede na njegov namen uporabe je čisto vseeno, če vzame TN. Naj ima kar se da velike vidne kote in dobre možnosti nastavljanja položaja, ostalo je pri TN ena in ista figa.
ddasd ::
a bi mi lahko potem kdo povedal kater monitor naj kupim :) ce ta ni tok ok :) prosim... kake konkretne primere :) hvala
hi
Matev ::
hp lp 24 inčni - mislim da je 2475 ali nekaj takega
Opkow ::
Po mojem mnenju je najboljse, da gres z laptopom v trgovino, pa si sprobas malo LCD-je.
Ker vsake oci imajo svojega malarja.
Lahko da bos z obicnim 24" TN LCD-jem neke firme bil super zadovoljen, ceprav ga je 3/4 foruma spluvalo do amena. :)
Jaz sem gledal vse mogoce LCDje, in me TN modeli niso prepricali niti pod razno. Na koncu sem se odlocil za DELL 2408WFP, ki je bil v spletnem BBju v akciji. Brat je vsel "navadnega" LG-ja z TN matriko, kjer se lepo vidi stopnicast preliv barv in za povr se nakoliko sprane, napram mojemu.
Je pa res, da pri obicajnem delu na TN modelu tega niti ne porajtas.
ddasd ::
Monitor LCD 24" HP LP2475w
je 200EUR dražji ( 540EUR )
Monitor LCD 24" Dell UltraSharp 2408WFP
skor 700EUR :)
js sm pa postal link od monitorja za 357 :) mislim daj e razlika očitna.. kater monitor za tako ceno ki sm jo js dal je najbolsi?:)
hi
Opkow ::
Sem spregledal tvoj prvi post, kjer si ze dal omejitev v ceni...
Ce mislis kupovat preko spletne trgovine, potem ni panike... Naroci ga, sprobaj, ce ti ne bo odgovarjal, ga lahko se vedno nazaj vrnes. Ali kot sem rekel, pojdi magar v BigBanga, Harvey Normana, ... pa si ga oz jih oglej od blizu. Kaksnih blazno hudih razlik med modeli iste velikosti, ce posebej pri LG-ju in Samsung-u, ne bos opazil. Ce jih, vzemi tistega, ki ti bolj ustreza. ;)
TN tehnologija je prakticno precej izpiljena do skrajnosti.
ddasd ::
ja zdj sm spet sam sebi prepuscen :) sm srcrno upal da bo dal kdo konkretne modele :) in reku če tega kupš boš presrečn :) jah bom se poskusu do bb zapelat pa pogledat tega 27" ( če ga majo ) pa kake dobre 24"
še vedno se priporočam če ma kdo kak ql stuff :)
hi
Ce ze na vsak nacin hoces TN monitor, vzemi najcenejsega. Vsi so enaki.
ddasd ::
kaj je to TN in kake so razlike in o čem se razlikujejo,..
a je to dobr al slabo? ne spoznam se nič na lcd:)
hi
  • spremenilo: ddasd ()
skrc ::
ne spoznaš se? preberi si zadnjih 53 strani pa boš svoje znanje o monitorjih izpilil do potankosti.
gre pa lestvica kvalitete nekako takole:
- TN
- MVA
- PVA (S-PVA)
- IPS (H-IPS in S-IPS)
ddasd ::
se pravi TN je najbols?
hi
Backup22 ::
Ne, ravno kontra ;)
ddasd ::
torej za 300 do 360EUR dobiš samo tega s TN matriko po domač povedan jajc?
hi
RookY ::
Če kupuješ velik TN, potem tale:
http://www.akcija.si/izdelek/67383/Moni...
Juhu juhu spet bom bruhu
ddasd ::
se pravi ta je bolsi od tistga k sm ga js postal? pa torej mi svetujs naj rajs kupm večjega kot pa 24" ?
hi
koliko ::
Fantje, če lahko kdo pomaga. Bi naročil Dell 2410 preko qsix:
http://www.qsix.eu/product_info.php/pro...
Kako je pol z garancijo v Sloveniji, če bi kej bilo oz. kdo je zastopnik pri nas?
A je že kdo kupoval prek te trgovine?
Tomo
  • spremenil: koliko ()
53 / 117
