Forum » Pomoč in nasveti » Ip naslov
Ip naslov
marko88 ::
Zivjo!
Za izpit iz PI bi rabil nek opis ip naslova oz kratko obrazložitev v cca 3-4 povedih. Ne bi smelo bit preveč strokovno in ne preveč laično. Bi bil kdo tolk dober?
StratOS ::
An identifier for a computer or device on a TCP/IP network. Networks using the TCP/IP protocol route messages based on the IP address of the destination. The format of an IP address is a 32-bit numeric address written as four numbers separated by periods. Each number can be zero to 255.
"Multitasking - ability to f##k up several things at once."
"It works better if you plug it in."
"The one who is digging the hole for the other to fall in is allready in it."
| » | Izredno počasen brskalnik ?!Oddelek: Omrežja in internet | 2286 (1659) | clemense |
| » | En zelo čuden bugOddelek: Pomoč in nasveti | 1942 (1355) | fastfury |
| » | resitev: Kako nastavit routerOddelek: Omrežja in internet | 3503 (3197) | nicjasno |
| » | Povezava dveh mašin!W2kOddelek: Pomoč in nasveti | 2661 (2473) | ~Panter~ |
| » | končno.....ADSL!Oddelek: Omrežja in internet | 2131 (1682) | MUC |
