New RADEON 8500 from Gigabyte: Feel the difference!
_Mortal_ ::
Apparently, Gigabyte has changed the layout of their RADEON 8500 board. The reason? Better cooling or funky look, who really cares? Here we go with the pictures:
GIGABYTE MAYA AP64D-H (RADEON 8500 PRO)
Retail Package of the board above:
GIGABYTE MAYA AP64D-H (RADEON 8500 DELUXE)
If we take a look at the pictures, we will surely find a number of differences, not very important, to tell you the truth. However, we should note that with every document from Gigabyte we obtain, we obtain the new specifications as well. For example, when we first reported about the Taiwanese company to announce retail ATI based videcards, we told that 3.5 ns DDR SDRAM memory was going to be used for the RADEON 8500 accelerator and also VIVO functions was going to be added. Then, a couple of weeks later our sources at Gigabyte supplied us with another information, according to which, 3.6 ns memory was going to be put instead of 3.5 ns DDR SDRAM, also the VIVO connectors "dissappeared" from the list of specifications, however, additional "MAGIC WIND" fan on the tail of the had been added.
According to the documents we have now, the board will be equipped with 64 MB of 3.6 ns DDR and clocked at 275/275 MHz core/memory; VGA, DVI and TV-Out connectors are maintained onboard. As the previous "versions", this very board has hardware monitoring functions and advanced cooling system.
So, let us hope that these specs are final and the RADEON 8500 from Gigabyte Technology will finally hit the stores soon.
Komi čakam !!!!!!!!!!!!!!!!!
Is reading in the bathroom considered as multi-tasking?
Sergio ::
se vam ne zdi, da bo tudi po Gigabyteovi izvedenki ATIjeva referenčna še vedno carovala? mogoče sem pa samo paranoičen...
Tako grem jaz, tako gre vsak, kdor čuti cilj v daljavi:
če usoda ustavi mu korak,
on se ji zoperstavi.
BC3 ::
:D>:D:)at last!
-:| athlon x2 5000->phenom fx-5000@3G, vapor-x 4890, aeneon xtune |:-
luni ::
Pocakajmo na Herculesove modre lepotice :)
Artificial Intelligentia
ChiefThunder ::
speaking of which...
8-)
... po liniji najmanjšega odpora. ;)
Matek ::
Meni se zdi Gigabytov lepši
jRk0 ::
Gigabyte je lepsi, pa se rame ma hlajene...
BC3 ::
red rulz!
radeon 7500 ::
hhhuuuuuuuuuuuudooooooooooooooo lepo . ja .
Sam še cena:D dol pade, pa bo.
KOMI ČAKAM...
(red je lepši, čeprou tud z modro nimam problemov:)))
radeon
danielka84 ::
mene pa zanima, če bo kaki Radeon8500 z Video-In?
kot je bil Radeon VIVO?
Radeon8500 DV je predrag!;(
_Mortal_ ::
Kup Radeon 7500DV. RAzlike med Gigabaytovim in Herculesovim Radeonom. Herculesov je LE verzija Gigabaytova pa cela. Pa še Herculesov me tiste kurce med rami isto kot Ati-jeva verzija zato ne morš gor dat nevem kakšne tiste kurce k grejo na ram.
Drugač mi je modra lepša barva!>:D
JohnyB ::
Ja men je pa vseen ker mam ATIja in leti kot strela in me res malo en ...... zanima kakšn barve je kartica !
Ker bistvoje v tem da leti .....
Pa naj kdo reče da se motim, ker barvo kartice ne občudujem ker jo ne vidim .....
vidm pa kako leti .... :D
..je pa fino da je več proizvajalcev, ker seveda cene padajo ....in padajo ...
Apple iMac
JLP ::
Ja bi se strinjov da barva lih ni pomembna, važn je da leti, pa da je slika uredu, tako 2D kot 3D. Konkurenca pa kot vedno izredno dobrodošla.
Live long and prosper!
katerga radeona
191532 (1257) bond007
Poden od podna: Hecules in R8500 LE (strani: 1 2 3 )
1429301 (6526) rap3r
RADEON 8500 retail ali LE
111577 (1286) kuglvinkl
ATI to reduce prices! And its already happening.
81601 (1354) kuglvinkl
Pazite na to
111875 (1476) Dami
