Forum » Programiranje » [VBScript] Brisanje temp
Microsoft ::
Nekaj sem caral z VBScript, ce bo kdo rabil. Je se mogoce kak napakica vmesa, samo nekaj ze dela. Skripta rabi za zagon parameter, ki je crka pogona, kjer hocemo pobrisati temp. Recimo, primer ce imamo na c particiji: cscript Skripta.vbs c
Koda:
by Miha
p.s.: Zakaj mora bit vnos kode tako blesav?!
Koda:
'Error
On Error Resume Next
'Dim
Dim rootDrive
Dim documentsAndSettings
Dim localSettings
Dim localTemp
documentsAndSettings = "\Documents and Settings"
localSettings = "\Local Settings\Temporary Internet Files"
localTemp = "\Local Settings\Temp"
'Get arguments
If Wscript.Arguments.Count = 1 Then
rootDrive = Wscript.Arguments.Item(0) & ":"
Else
Wscript.Echo "Usage: cscript Skripta.vbs C"
Wscript.Quit
End If
'Get all user accounts
Set fso = CreateObject("Scripting.FileSystemObject")
Set documentsAndSettings = fso.GetFolder(rootDrive & documentsAndSettings)
Set accounts = documentsAndSettings.Subfolders
For Each account in accounts
EnumAllSubs fso.GetFolder(account & localSettings)
If Err.Number <> 0 Then
Wscript.Echo account & localSettings
Wscript.Echo "Error0: " & Err.Description & VbCrLf
Err.Clear
End If
EnumAllSubs fso.GetFolder(account & localTemp)
Wscript.Echo "Error3: " & Err.Description & VbCrLf
Err.Clear
End If
Next
Sub EnumAllSubs(folder)
For Each subfolder in folder.SubFolders
For Each file In subfolder.Files
If fso.FileExists(file.Path) Then
fso.DeleteFile(file.Path)
End If
Wscript.Echo "Error1: " & Err.Description
Err.Clear
Else
Wscript.Echo "File " & file.Path & " deleted"
End If
Next
EnumAllSubs subfolder
Next
If fso.FolderExistst(folder) Then
fso.DeleteFolder(folder)
End If
Wscript.Echo "Error2: " & Err.Description
Err.Clear
Else
Wscript.Echo "Folder " & file.Path & " deleted"
End If
End Sub
by Miha
- spremenil: Microsoft ()
| » | vba arrayOddelek: Programiranje | 1352 (1045) | Vazelin |
| » | [C] izris trikotnika v konzoliOddelek: Programiranje | 4669 (2944) | darkkk |
| » | [VB] brisanje polne mapeOddelek: Programiranje | 1168 (1095) | jishiri |
| » | Kako bi napisal .bat file, da bi ...Oddelek: Programiranje | 2279 (1725) | AtaStrumf |
| » | vkljucevanje txt datoteke v ...Oddelek: Programiranje | 2002 (1778) | webblod |
