Forum » Programiranje » [VB] brisanje polne mape
jishiri ::
zdravo
malo sem se igral in bi naredil program ki bi brisal premikal koperal datoteke in mape... sedaj se mi je ustavilo pri brisanju polne mape.. (prazne lepo brise)
hvala za pomoce in nasvete...
Private Sub Button2_Click(ByVal sender As System.Object, _
ByVal e As System.EventArgs) Handles Button2.Click
For Each Item As IO.FileInfo In _ Me.CheckedListBox2.CheckedItems
Try
If Item.Exists = True Then Item.Delete()
Catch : End Try
Next Item
For Each Item As IO.DirectoryInfo In Me.CheckedListBox1.CheckedItems
Try
Catch : End Try
Next Item
end sub
- spremenil: Primoz ()
*ziga* ::
Public Function KillFolder(ByVal FullPath As String) _
As Boolean
'PURPOSE: DELETES A FOLDER, INCLUDING ALL SUB-
' DIRECTORIES, FILES, REGARDLESS OF THEIR
' ATTRIBUTES
'PARAMETER: FullPath = FullPath of Folder to Delete
'RETURNS: True is successful, false otherwise
'REQUIRES: 'VB6
'Reference to Microsoft Scripting Runtime
'Caution in use for obvious reasons
'EXAMPLE: 'KillFolder("D:\MyOldFiles")
On Error Resume Next
Dim oFso As New Scripting.FileSystemObject
'deletefolder method does not like the "\"
'at end of fullpath
If Right(FullPath, 1) = "\" Then FullPath = _
Left(FullPath, Len(FullPath) - 1)
If oFso.FolderExists(FullPath) Then
'Setting the 2nd parameter to true
'forces deletion of read-only files
oFso.DeleteFolder FullPath, True
KillFolder = Err.Number = 0 And _
oFso.FolderExists(FullPath) = False
End If
End Function
Private Sub Form_Load()
KillFolder "C:\test"
End Sub
To bi moralo delat.Drugic poisci malo po netu.
BigWhale ::
Pobrisat še moreš datoteke in mape v tej mapi. Uporabiš rekurzijo
Ja, sam glej, da ti ne bo stacka zmanjkal!!!
jishiri ::
hvala za te vrstice... sem stvar resil na podoben nacin, le malo se razlikuje, da brise v ciklih, glede na kolicino faila v sami mapi in ostalih podmapah... da ne bi prihajalo do neodzivnosti programa...
hvala za pomoc...
LP, JM
hvala za pomoc...
LP, JM
- spremenilo: jishiri ()
| » | Visual BasicOddelek: Programiranje | 4266 (3292) | cekr |
| » | [VB] polepšanje kodeOddelek: Programiranje | 1147 (1053) | korenje3 |
| » | [VB] Komunikacija s serijskimi napravamiOddelek: Programiranje | 2733 (2007) | mNeRo |
| » | VB.net MDI in formi splošnoOddelek: Programiranje | 1978 (1921) | strel |
| » | vkljucevanje txt datoteke v ...Oddelek: Programiranje | 2005 (1781) | webblod |
