[VBScript] Brisanje temp
Microsoft ::
Nekaj sem caral z VBScript, ce bo kdo rabil. Je se mogoce kak napakica vmesa, samo nekaj ze dela. Skripta rabi za zagon parameter, ki je crka pogona, kjer hocemo pobrisati temp. Recimo, primer ce imamo na c particiji: cscript Skripta.vbs c
Koda:
'Error
On Error Resume Next
'Dim
Dim rootDrive
Dim documentsAndSettings
Dim localSettings
Dim localTemp
documentsAndSettings = "\Documents and Settings"
localSettings = "\Local Settings\Temporary Internet Files"
localTemp = "\Local Settings\Temp"
'Get arguments
If Wscript.Arguments.Count = 1 Then
    rootDrive = Wscript.Arguments.Item(0) & ":"
Else
   Wscript.Echo "Usage: cscript Skripta.vbs C"
   Wscript.Quit
End If
'Get all user accounts
Set fso = CreateObject("Scripting.FileSystemObject")
Set documentsAndSettings = fso.GetFolder(rootDrive & documentsAndSettings)
Set accounts = documentsAndSettings.Subfolders
For Each account in accounts
    EnumAllSubs fso.GetFolder(account & localSettings)
    If Err.Number <> 0 Then
        Wscript.Echo account & localSettings
        Wscript.Echo "Error0: " & Err.Description & VbCrLf
        Err.Clear
    End If
    EnumAllSubs fso.GetFolder(account & localTemp)
        Wscript.Echo "Error3: " & Err.Description & VbCrLf
        Err.Clear
    End If
Next
Sub EnumAllSubs(folder)
    For Each subfolder in folder.SubFolders
        For Each file In subfolder.Files
            If fso.FileExists(file.Path) Then
                fso.DeleteFile(file.Path)
            End If
                Wscript.Echo "Error1: " & Err.Description
                Err.Clear
            Else
                Wscript.Echo "File " & file.Path & " deleted"
            End If
        Next
        EnumAllSubs subfolder
    Next
    If fso.FolderExistst(folder) Then
        fso.DeleteFolder(folder)
    End If
        Wscript.Echo "Error2: " & Err.Description
        Err.Clear
    Else
        Wscript.Echo "Folder " & file.Path & " deleted"
    End If
End Sub
by Miha
p.s.: Zakaj mora bit vnos kode tako blesav?!;((
vba array
Oddelek: Programiranje
121370 (1063) Vazelin
[C] izris trikotnika v konzoli
134693 (2968) darkkk
[VB] brisanje polne mape
51184 (1111) jishiri
Kako bi napisal .bat file, da bi ...
232294 (1740) AtaStrumf
vkljucevanje txt datoteke v ...
132018 (1794) webblod
