MS Windows Vista Sidebar za XP
prehlajeni ::
Oj,
se dobi uradni mikrosoftov windows vista sidebar ki poganja gadgete tudi za xp-je?
hvala!
a9753 ::
...a niso te geđeti sam za visto? se da na xpjih?
StratOS ::
Vista transformation pack 6 final + še veliko ostalih vista like opcij
"Multitasking - ability to f##k up several things at once."
"It works better if you plug it in."
"The one who is digging the hole for the other to fall in is allready in it."
  • spremenila: StratOS ()
Vista transform pack
Oddelek: Operacijski sistemi
71570 (1356) RejZoR
finte
71149 (1149) OmegaBlue
kako se naštima to v XP windows??
101478 (1368) ta_pravi
Kako sprmeniti gumb start - menuja
51283 (1194) Anze92
teme za xp
61487 (1444) BluPhenix
