lilo
lilo
korenje_ver2 ::
Mene zanima, zakaj vidim ene 100 stevilk "99" ob zagonu pcja, na katerem sem instaliral mbr in lilo. Prej sem namrec disk skopiral na drugi disk z ukazom cd / && echo cp -a -v `/bin/ls -1Ab | egrep -v "^newdisk$|^proc$"` /newdisk | sh
nato sem z lilotom ustvaril mbr in skopiral lilo gor. no karkoli ze, ne dela. kva sm anrobe nareud?
roscha ::
What is L 99 99?
"99 indicates an invalid second stage index sector; this error relates to a disk read error, normally an issue with reading the map file. Generally the underlying cause is some confusion over BIOS device codes; i.e., the map file is not on the BIOS device code which was used for the disk in question when LILO was installed.
Two solutions:
1. Use: disk=/dev/hdX bios=0x8N # X=a,b,c,... N=0,1,2,... to resolve the BIOS codes explicitly.
2. Use LILO version 22.5 or later (22.5.8 is current), which boots by disk VolumeID, resolving the BIOS codes at boot time.
#2 is the more fault tolerant approach."
Sploh pa priporočam uporabo GRUB-a. LILO je nekako deprecated.
korenje_ver2 ::
to ne dela...
hmm grub? kwa je to :P
ze 15 let mam lilo gor... hmm
ender ::
GRUB. Priporočam grub legacy, ker je dobro preizkušen, za razlio od GRUBa 2, ki ima občasno še vedno kakšne težave.
korenje_ver2 ::
ok zdej ... kva moram narest, da odstranim ta star disk in uporabim novega?
oz da dam trenutni /dev/hda stran in dam /dev/hdb na /dev/hda ter novi disk na /dev/hdb, tako da se mi potem ta prejsnji /dev/hdb boota ki bo zdej /dev/hda...
roscha ::
Prištekaj hdb namesto hda. Hda daj zaenkrat v predal :D
Potem beri tukajle.
Namesto diskete svetujem CD/DVD.
korenje_ver2 ::
mah sm zajebu vse skupi..... nej gre v picko zakva ni noben prej reku da vse ostale diske odklopm. v glavnem napacn disk sm formatiru :(
faaaaaaaaaaak
nc cudnga da ni delal
Nisi prvi, ne zadnji :)
roscha ::
@korenje
Saj sem ti napisal da daj hda v predal. BERI :D :D
roscha ::
Drugače pa takle zajeb ni nič hudega. Veš za drugič da je treba bit pazljiv ko si root.
Sam sem 1x poslal inštalacijo v večna lovišča, ker sem v napačni konzoli naredil chmod 775 -R
Namesto nekega direktorija pod user acc. sem chmodal cel disk.
Rešitev? Ni bilo druge kot reinstall.
No pa tudi napačno mašino sem že ugasnil, ker nisem bil pozoren KDO@KAJ sem...
korenje_ver2 ::
na sreco sm mel sam muvije na unem disku, ka je bil sharan v omrezju. tko da ni panike. sploh pa je bla beda, ka sta oba diska enake velikosti in iste firme.
lilo boot loader problem
Oddelek: Operacijski sistemi
152460 (2092) Michael7
Novell Open SuSE Linux 10.1, problem z /dev/hdb
161789 (1648) simper
Dva diska, dva OS, en GRUB -> kako izklopit grub in linux
132290 (2128) zee
Prehod iz kernel-2.4.26 na 2.6.10 in problem
181797 (1656) Shaman
gentoo,grub čaka minuto ob zagonu
51397 (1330) potepuh
