Problem pri nastavitvi dostopa na router (SSH)
Goldee ::
Rad bi omogočil dostop na router (Cisco 1812) preko ssh-ja (port 22). Na Ciscotovi strani moj problem opisujejo kot:"You are encountering Cisco bug ID CSCdv70159"
Zgodi se pa tole:
c1812demo#conf t
Enter configuration commands, one per line. End with CNTL/Z.
c1812demo(config)#crypto key generate rsa
% You already have RSA keys defined named c1812demo.word.
% Do you really want to replace them? [yes/no]: yes
Choose the size of the key modulus in the range of 360 to 2048 for your
General Purpose Keys. Choosing a key modulus greater than 512 may take
a few minutes.
How many bits in the modulus [512]: 512
% Generating 512 bit RSA keys, keys will be non-exportable...[OK]
c1812demo(config)#^Z
c1812demo#show ip ssh
SSH Disabled - version 1.5
%Please create RSA keys to enable SSH. /* zakaj se mi to napiše?
Authentication timeout: 100 secs; Authentication retries: 3
c1812demo#
Kaj naj storim, da zaobidem tega bug-a, oz. kako naj omogočim dostop na portu 22?
Hvala za pomoč!
salesky ::
Zdej sicer nepoznam tolk tega da bi ti znal povedat samo a SSL je sploh omogočen? Ker piše SSH disabled.
Sm malo prebrskal na netu pa najdu to stran: KLIK
rk8 ::
Goldee,
poskusi z ukazom
ip ssh rsa keypair-name c1812demo.word
(ključe si namreč uspešno naredil, samo uporabiti jih še moraš).
http://www.cisco.com/univercd/cc/td/doc/product/software/ios123/123newft/123t/123t_4/gt_ssh2.htm#wp1054168
LPr
Goldee ::
Hvala za pomoč rk8! Sedaj zadeva deluje. :)
Tezave z online igranjem prek brezzicnega routerja
81381 (1194) brdi
OpenSSH za Windows in certifikat
Oddelek: Omrežja in internet
62921 (2921) Poldi112
Varnost openSSH
242923 (2501) Volk|
[C#] je možno?
Oddelek: Programiranje
191762 (1358) Kekec
Cisco SOHO91-konfiguracija
222515 (2123) ponky
