Wolfenstein in XP???! :o(
zrebec ::
;(En problemcek je nastal pri XPjih z Wolfensteinom. Namrec po uspesni instalaciji Wolfa ni mozno zagnati. Javi mi error Cannot find OpenGL! Ali je imel kdo kaksne podobne probleme ali ima vsaj predlog kaj storiti?!
Msi K7T Turbo2, AMD Duron 1k, GeForce 64,....
JLP ::
RTCW dela čist dobr u WinXP. Dej počekirej da si prov drajverje za grafo inštaliro.
Live long and prosper!
zrebec ::
am jah ..... nawem ........ jst sm sistem cist na nov postavu, masina je tut nova skorej ........ pa ne dela .... no ja ..... prej sm mu 2k pa je cist normaln delal ..... a tle me jebe u glavo ...... so pa driverji za xp pa use pupedenan tko da nebiveduzglave zato pa sprasujem ce se je kermu ze to pojavl kse mi ne zdi logicn
hvala useen ane .. sm probou pa so driverji cist up-to-date|O
zrebec ::
evo ce bo kdo kej vec vedu!
sam kva pa nej zj s temu 3dfxom alkva muri?
Wolf 1.0.0 win-x86 Nov 13 2001
----- FS_Startup -----
Current search path:
E:\RETURN~1\main\sp_pak2.pk3 (232 files)
E:\RETURN~1\main\sp_pak1.pk3 (1342 files)
E:\RETURN~1\main\pak0.pk3 (4775 files)
E:\RETURN~1/main
6349 files in pk3 files
execing default.cfg
couldn't exec language.cfg
couldn't exec wolfconfig.cfg
execing autoexec.cfg
Hunk_Clear: reset the hunk ok
...detecting CPU, found AMD w/ 3DNow!
Bypassing CD checks
----- Client Initialization -----
Cmd_AddCommand: map_restart already defined
----- Initializing Renderer ----
----- Client Initialization Complete -----
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:\WINNT\System32\opengl32.dll' ): succeeded
...setting mode 3: 640 480 FS
...using desktop display depth of 32
...calling CDS: ok
...registered window class
...created window@0,0 (640x480)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 32, 24, 8 )
...35 PFDs found
...GLW_ChoosePFD failed
...GLW_ChoosePFD( 32, 24, 0 )
...35 PFDs found
...failed to find an appropriate PIXELFORMAT
...restoring display settings
...WARNING: could not set the given mode (3)
...using colorsbits of 16
...calling CDS: ok
...GLW_ChoosePFD( 16, 16, 0 )
...35 PFDs found
...35 PFDs found
...shutting down QGL
...unloading OpenGL DLL
...assuming '3dfxvgl' is a standalone driver
...initializing QGL
...WARNING: missing Glide installation, assuming no 3Dfx available
----- CL_Shutdown -----
RE_Shutdown( 1 )
GLW_StartOpenGL() - could not load OpenGL subsystem
Aljo1 ::
Meni dela vse OK v XP-jih. Z rivo TNT 2
Fresh Prince ::
Jaz mam tut Riva tnt2 & Det. 27.10
Dela brez problemov.
zrebec ::
:))prou namorm vrjet .......... jeftino ......... ampak ratal je .......... ene 3x drajverje gor pa dol pa gor pa dol ........... pa stvar kr od jednog dela. hvala useen za pumoc :O)
Wolfenstein - Enemy Territory (strani: 1 2 3 4 … 19 20 21 22 )
Oddelek: Igre
1096105990 (22998) Gregor459
Problem z nvidio
171892 (1640) lanicorec
Problem z zagonom iger RTCW in MOHAA
Oddelek: Igre
153102 (2786) Flay
Medal of Honor in merzno igranje?
Oddelek: Igre
61295 (1157) mitopuzo
Hercules Radeon 8500 FDX+Quake3
51307 (1191) matter
