Legalnost 3rd-party MSN klientov
darkolord ::
OK, ker enim očitno ni všeč, da tole omenjam v temah o MSN klientih (in tam ne dobivam nobenega odziva na to) odpiram posebno temo za tole...
Konkretno se gre o legalnosti ne-MSjevih klientov, ki se uporabljajo za dostop do MSN omrežja, na primer Gaim, Miranda, amsn, ...
v TOU od Windows Live/MSN piše, da ni na servis ni dovoljen dostop z 3rd party neavtoriziranimi klienti:
4. How You May Not Use the Service.
In using the service, you may not:
use the service in a way that harms us or our affiliates, resellers, distributors, and/or vendors (collectively, the “Microsoft parties”), or any customer of a Microsoft party;
use any portion of the service as a destination linked from any unsolicited bulk messages or unsolicited commercial messages (“spam”);
use any unauthorized third party software or service to access the Microsoft instant messaging network (currently known as the .NET Messenger service);
use any automated process or service to access and/or use the service (such as a BOT, a spider, periodic caching of information stored by Microsoft, or “meta-searching”);
use any unauthorized means to modify or reroute, or attempt to modify or reroute, the service;
damage, disable, overburden, or impair the service (or the network(s) connected to the service) or interfere with anyone’s use and enjoyment of the service; or
resell or redistribute the service, or any part of the service.
You can find a list of authorized third-party software at http://messenger.msn.com/Help/Authorized.aspx.
Kako je zdaj s tem?
A imaš slabo vest, al kaj? Koga briga. Dokler te ne zaprejo, veselo na delo :D Ne, ampak resno... protokol za trenutno sporočanje bi moral biti nekako standardiziran in odprt (po mojem). Ker, dajmo biti realni, ti se ne priklopiš na program, ampak na internet/omrežje (ajde, MSN serverje), podobno, kot P2P.
Res, zakaj ne uporabljajo podobno tehnologijo, kot Torrenti? Da bi namesto strežnikov uporabljali uporabnikovo pasovno širino?
darkolord ::
Ne, sploh nimam slabe vesti...
Sam na slo-techu je polno ljudi, ki jim to, da je vse legalno (Matthai na primer :D), pomeni več kot karkoli drugega... Odgovora na tole pa se vztrajno izogibajo...
Torrenti pa so za chat precej neprimerni: še vedno rabiš serverje (tracker), vsaj en uporabnik (od obeh) mora imeti odprt port (česar večina nima), itd. Sicer tole ne spada v to temo 8-)
'FireSTORM' ::
in nekdo si na linux naj naloži windows live messanger:\
so bendi...torej uporabniki linuxa so nezaželjeni oz. prepovedani na msn...
ti pa ne boš šel z nami na pijačo kr voziš audija in ne bmwja...haha!:\
Those penguins.... They sure aint normal....
OmegaBlue ::
Ok zadevo sem malo raziskal, ker me resno zanima tvoje vprašanje. Microsoft se je seveda na začetku upiral in tupil svoje (as always) a kmalu spoznal da tako ne bo šlo, torej odprl je svoj protokol MSN Messenger Service 1.0 Protocol - to je prva različica, sedaj je že pri 15 (last time i checked). Obstaja seveda tudi obsežna dokumentacija za vse novejše protokole MSNPiki.
Edina stvar ki naj bi pri tem lahko bila (legalno) sporna je tole:
Client ID string Client ID code
msmsgs@msnmsgr.com Q1P7W2E4J9R8U3S5
PROD0038W!61ZTF9 VT6PX?UQTM4WM%YR
PROD0058#7IL2{QD QHDCY@7R1TB6W?5B
PROD0061VRRZH@4F JXQ6J@TUOGYV@N0M
Stvar je bila predvidevano pridobljena z debugingom clienta ali leekana iz microsofta. ID pa se uporablja pri server pingih ali drugače imenovanih izzivih (Challenges), ki jih server pošilja pri preverjanju povezave. Client mora odvrniti pravilno md5 vrednost kombinirano iz stringa, ki ga server pošlje in clientID-ja.
Čeprav velika večin alternativnih klientov ne uporablja najnovejšega protokola, nevem ali je to iz legalne perspektive ali stabilnosti delovanja. Seveda pa pri microsoftu lahko kupijo licenco ali pa pravice za uporabo, kot to zadnje čase počnejo firme/proizvajalci določenih BOT-ov na MSN.
Vsa dokumentacija naj bi bila tudi na voljo v MSDN library.
EU zakonodaja takšne pogoje uporabe prepoveduje, tako da so nični.
Uporaba 3rd party programov za povezavo na MSN je tako v EU vsekakor legalna, po drugi strani pa Microsoft na Microsoftovih strežnikih lahko počne praktično kar želi (če se pri tem drži ameriških zakonov) in tako blokira račune, ki uporabljajo tako programsko opremo.
Najbolje je seveda, če uporabljate odprt protokol.
64202 ::
No jaz sem si naredil račun na passport.net in nisem tega opozorila nikjer videl. Potem lahko vpišeš u+p v gaim in prideš notri. Kdo je zdaj kriv? Jaz? Programerji gaima? Kaj naj bi MS dejansko naredil v takem primeru?
Nazadnje me bo še kdo tožil, ker sem šel s firefoxom na nek pejdž :\
I am NaN, I am a free man!
darkolord ::
A imaš mogoče kakšen link ali kaj podobnega?
Za razlago te pogodbe za Slovenijo se uporablja Luksemburška zakonodaja
Na dnu strani imaš povezavo "Pravne informacije", kjer pa te preusmeri točno na ta link v mojem prvem postu...
AFAIK ker nimajo popolne dokumentacije
64202 ::
Hm, ko sem se jaz pred časom (ko si spraševal za legalnost) šel za hec še enkrat prijavit, tega ni bilo.
darkolord ::
Zdaj je res malo drugače, ja. Vem pa, da je včasih na passportu pisalo, da moraš spoštovat TOS od vseh servisov, ki jih boš s tem usernameom uporabljal...
darkolord ::
Bump.
Ma že kdo kaj konkretnega kot odgovor na tole? :)
Mal sem še po netu gledal, tole vprašanje se je že večkrat pojavilo; očitno je, da vsi ti 3rd party klienti kršijo pogoje uporabe MSN servisa (so "ilegalni"), le da se ta veliki za to očitno ne zmenijo preveč. Tukaj je očitno enako 8-)
Če smo natančni, je tole tako kot kršenje EULA, pri čemer pa na STju vsi takoj dobijo mozoljčke :P
Tic ::
Jst ne dobim mazolov niti po majonezi.
Darko, ne razumem kaj bi ultimativno rad dosegel? Da se msju plača? Da ukinejo kliente? Da bi ti naredil svojega? :)
persona civitas ;>
Daedalus ::
Mah, hoče dokazovati vsem uporabnikom neMS opreme, da s(m)o navadni nelegalni prasci0:)
Resno, kaj hočeš s tem dosečti/povedati? Da smo uporabniki gaima kriminalci?
[J.P.Sartre]
darkolord ::
Sploh ne.
Zanima me samo, v čem je razlika med tem, če naprimer "JanezN" na forumu sprašuje nekaj, ki je v nasprotju z recimo XPjevim EULA in tem, da se pogovarja o zadevah, ki kršijo MSNjev TOU.
V prvem primeru mu je namreč takoj postrežena povezava.
Čisto verjetno gre pa samo za pristranskost
Nejc Pintar ::
AFAIK ta EULA ni ravno kompatibilna z EU zakonodajo?
edit:
Sicer pa 3d party clienti niso nujno namenjeni uporabi MSNja.
Lahko je biti prvi, če si edini!
darkolord ::
A imaš kakšen link?
Zaposleni v Microsoftu skrivnosti kradel kar prek SkyDriva
1711094 (8513) Phantomeye
Google Talk (strani: 1 2 3 )
10818294 (12117) slitkx
Cenzura v MSN Messengerju (strani: 1 2 3 )
Oddelek: Novice / Zasebnost
13120077 (15757) 64202
MSN Messenger napaka:80072efd
Oddelek: Programska oprema
93464 (3356) JC_DENTON
Kako odstranit čuden AD
Oddelek: Omrežja in internet
51190 (1091) Spajky
