Kako odstranit čuden AD
matter ::
Evo ne morm odstrant.
Sm probu adaware in pa tut spy sweeper in pri obeh najnovejše definicije pa nč.
Firewall ne blokira, ker očitno prihaja preko messengerja.
NE rečt da nej odstranm messenger.
Grem basket pa bom neloke metal
  • zavaroval slike: Predator ()
OmegaBlue ::
erm takile mesiđi ponavat prihajajo preko "net send" komande, torej ti ti nekdo pošilja.
Prvič vidim spam u taki obliki..
McHusch ::
matter ::
Tnx Mc....
Cokolesnik ::
Uporabniki naj pred pisanjem sporočil uporabljajo iskalnik www.google.com.
Čokolešnik ne vsebuje nobenih aditivov, konzervansov ali umetnih barvil.
Spajky ::
Še en kopi-pejst:
Disable the windows messenger service. (BTW It's not the same as MSN
messenger). Right-click on "my computer", and choose "manage". Go to the
"services" section, and find the windows messenger service. Double-click
that entry. Set it's start-up behavior as "disabled", then stop the service,
or reboot the computer. You should no longer recieve pop-ups that use the
windows messenger service. That service was intended for local network
messaging. Disabling it won't harm anything.
8-)
Windows 2000?????
Oddelek: Operacijski sistemi
81319 (1236) darkolord
Od česa se pojavlje tole okno?
Oddelek: Omrežja in internet
272167 (1585) Bakunin
Ponovna poplava popravkov
Oddelek: Novice / Varnost
203354 (3354) andrej
Kako izklopit Windows MESSENGER ?!
172024 (1667) krucymucy
