Maya 8.0 licenca
Maya 8.0 licenca
origin92 ::
Lahko kdo razloži to?
probal sem že vse, pa ni delovalo...
1. First Create a directory on the c: drive (even if you install maya on different drive) called
FLEXLM
2. Copy the aw.dat and awkeygen.exe file to this directory.
3. Install Maya
4. Goto start-->all programs-->Autodesk-->common utilities-->FlexLM license utilities
5. Under system settings copy Ethernet address
6. Open the file (from the directory FLEXLM) aw.dat with Wordpad and replace the words "your host"
with the copied Ethernet address. Save and close wordpad
7. Using the run utility and type: awkeygen.exe aw.dat
8. Goto start-->all programs-->Autodesk-->Maya 8.0-->Install license
select "I would like to install license from a file"
9. Browse to the path of the file aw.dat
10. Click install
11. Restart computer
jurre ::
tukaj imas razlozeno>:D
OmegaBlue ::
Pomoči pri nelegalni programski opremi ne nudimo.
Mac OS Snow Leopard na PC
Oddelek: Operacijski sistemi
485631 (4179) Gray_Warden_
Apache - localhost JA, IP naslov NE
Oddelek: Omrežja in internet
187272 (7131) ManDriver
Zeus - Master of Olympus
Oddelek: Igre
92166 (1997) dustphoenix
Ne predvaja novega audio CD
52606 (2562) Tea Time
Whitler (strani: 1 2 3 )
10910051 (8493) zetko
