Forum » Igre » Fear problem
Fear problem
Tammih ::
Sm si z neta sneu zastonj verzijo Fear Combat.. Ko jo zaženem mi izpiše "A required security module can not be activated. This program can not be executed."
Lahko kliknem le OK, ki me vrže vn.. V čem je fora, zaščito sm že probou ugasnt pa isto serje
Tr0n ::
To je ze blo parkrat napisano. Malo posearchaj. Google is your friend.
Ponavadi moras izklopit virtual programe (Alcohol, Deamon Tools) ali registry tweak. Baje da pomaga tudi nastavitev Windows2000 Compatibility.
run regedt32.exe
go to HKEY_LOCAL_MACHINE then to SYSTEM (this is the mistake) then to MountedDevices and finally
right click over this directory. Select permisions. Select administrators and finally allow full control and read.
run regedt32.exe
| » | Windows 7 Installer (64-bit) - težaveOddelek: Programska oprema | 3728 (3118) | fr!Xy |
| » | Optiarc DVD RW AD-5170AOddelek: Pomoč in nasveti | 1208 (1145) | Han |
| » | Virus uniču cd-rom!! nujnoOddelek: Pomoč in nasveti | 2687 (2115) | alesrosina |
| » | Disk 200GB je v winsih samo 128GB?Oddelek: Pomoč in nasveti | 1538 (1422) | danielka84 |
| » | winXP tezavaOddelek: Operacijski sistemi | 1250 (1029) | ToniT |
