Server 2003
Server 2003
BadB0y ::
Ko se hocem logirat na server preko remota mi javi tole v logu. Takrat me da v temp profile
Windows cannot load the locally stored profile. Possible causes of this error include insufficient security rights or a corrupt local profile. If this problem persists, contact your network administrator. DETAIL - The process cannot access the file because it is being used by another process.
Javi pa da ntuser.dat uporablja nek drug program. Ce server restartam se lahko normalno prijavim. Po 2 dneh pa je ista pesem. Ima kdo mogoce kaksno resitev? Tudi probal sem zbrista local profil od tega uporabnika in ob novi prijavi ti nanovo skreira localni profil. In spet 2 dni in isto.
LP Dejan
BadB0y ::
Kaj res ni nobenega ko bi mi znal pomagat?????
Windows can not found a locale profile
51075 (1051) zee
Wolfeinstain ET - LINUX !
Oddelek: Igre
322498 (2051) WamPIRe-
napaka pri logiranju
81403 (1320) Ziga Dolhar
win Xp - problem z userji
Oddelek: Operacijski sistemi
71354 (1219) miha
iz workgroup na domain
Oddelek: Programska oprema
141734 (1549) matic
