Forum » Pomoč in nasveti » infinite loop ???
infinite loop ???
BustA ::
pred kratkim sem kupil grafično. leadtek MX 400 64 MB, ki me v windowsih neki zajebava. Pri normalnih opravilih na netu (je odprtih več eksplorerjev), pri spreminjanju vobov v avi, pri pisanju v wordu, mi računalnik kar zašteka in pojavi se Blue screen in računalnik se mi znova zažene. Nadležno
Imam pa:
6163 BX Master
PII 350@420
MX 400 64 MB
384 MB rama
IC35 GB
Live player
in Windows XP
iz sporočila. ki me kasneje čaka v winsih sem dobil tole:
// Watchdog Event Log File
LogType: Watchdog
Created: 2002-01-13 21:52:09
TimeZone: -60 - Central Europe Standard Time
WindowsVersion: XP
EventType: 0xEA - Thread Stuck in Device Driver
// The driver for the display device got stuck in an infinite loop. This
// usually indicates a problem with the device itself or with the device
// driver programming the hardware incorrectly. Please check with your
// display device vendor for any driver updates.
ShutdownCount: 41
Shutdown: 0
EventCount: 10
BreakCount: 10
BugcheckTriggered: 1
DebuggerNotPresent: 1
DriverName: nv4_disp
EventFlag: 1
DeviceClass: Display
DeviceDescription: NVIDIA GeForce2 MX/MX 400
HardwareID: PCIVEN_10DE&DEV_0110&SUBSYS_285A107D&REV_B2
Manufacturer: NVIDIA
DriverFixedFileInfo: FEEF04BD 00010000 0005000D 00010887 0005000D 00010887 0000003F 00000008 00040004 00000003 00000004 00000000 00000000
DriverCompanyName: NVIDIA Corporation
DriverFileDescription: NVIDIA Compatible Windows 2000 Display driver, Version 21.83
DriverFileVersion: 5.13.01.2183
DriverInternalName: nv_disp.dll
DriverLegalCopyright: Copyright © NVIDIA Corp. 1996-2001
DriverOriginalFilename: nv_disp.dll
DriverProductName: NVIDIA Compatible Windows 2000 Display driver, Version 21.83
DriverProductVersion: 5.13.01.2183
Probal sem z različnimi drajverji (z zadnjih dveh natlačenkTM): 21.83, 22.80, sedaj pa imam gor 23.11 in bomo videli kako se bodo obnesli.
Imam pa:
6163 BX Master
PII 350@420
MX 400 64 MB
384 MB rama
IC35 GB
Live player
in Windows XP
LogType: Watchdog
WindowsVersion: XP
ShutdownCount: 41
Shutdown: 0
EventCount: 10
BreakCount: 10
EventFlag: 1
Devide Et Impera
destiny ::
Ta problem je predvsem znan pri VIA čipsetu in detonator driverjih v21.83 in višjih. Probej inštalirat kakšne prejšnje driverje ali pa poglej če za intlov čipset obstajajo kaki novi gonilniki z workaroundom...
PS: stari detonatorji imajo slabše zmogljivosti
destiny ::
Aja, pa še to...
WinXP so W2k z velik buggov in lepotno masko.
Jest sm jih mel, pa sm jih dol vrgu... Sami problemi
. Zdej mam W2k pro SP2 in so precej bolj stabilni.
Bo zgleda treba počakat na SP za XP-je
Pisk ::
tvoj cipset v teh winsih ne rabi gonilnikov.
probaj odstranit en modul, verjetno je problem z ramom.
Ti bom jaz enkrat zapiskal!!!!!!!!!
AngelOfDeath ::
Sem ugotovil edino rešitev ki ti 100% odpravi infinite loop.
Rešitev je nakup atijeve grafične kartice ker NVIDIO b... k.... če daš 130k za grafično ki je pol nemreš uporabljat nikjer.
jao sory nisem gledal datuma kdaj je blo vprašanje postavljeno :S
- spremenil: AngelOfDeath ()
| » | Windows XP Black screenOddelek: Pomoč in nasveti | 4812 (4552) | Twix |
| » | GEFORCE 4 TI 4200 problem....!!!!!Oddelek: Pomoč in nasveti | 1991 (1541) | Trupl0 |
| » | Geforce 2 mx 400 problemi z driverjiOddelek: Pomoč in nasveti | 1682 (1491) | akulp |
| » | 3d mark 2001 (strani: 1 2 3 )Oddelek: Pomoč in nasveti | 9336 (8209) | Doc |
| » | 23.11 DetonatorjiOddelek: Pomoč in nasveti | 1961 (1660) | SkyNet |
