Forum » Konzole » PSP in Wireless router
timm ::
Pozdravljeni.
Imam router Linksys WRV-200 in bi se rad povezal na PSP, pa mi nikakor ne uspe.
Verzija PSP-ja je 2.81.
Odstranil sem vse zaščite routerja, vse lepo najde, potem pa mi napiše tole:
A connection error has occurred.
A connection to the access point could not be established.
Check the security settings for the network and try again.
Lep pozdrav.
Lep pozdrav.
- premaknil iz Omrežja in internet: kuglvinkl ()
| » | Problem pri prijavi na Slo-TechOddelek: Slo-Tech | 1378 (1257) | smoke |
| » | Linked servers v MS SQL ServerOddelek: Programska oprema | 1482 (1449) | detroit |
| » | visual studio C# MSSQL error- rabim pomoč hitro!!!Oddelek: Programiranje | 2425 (2017) | kv1dr |
| » | Qemu -> Slackware host, Windows Xp guest, vpn problemiOddelek: Omrežja in internet | 1636 (1501) | zhigatsey |
| » | Problem pri ADSL connect-u!!!Oddelek: Omrežja in internet | 1326 (1186) | madmitch |
