router FBR-1418TX in fowarding
Juventus ::
kako naj fowardam port 80. Grem na fowarding roules, pol pa na virtual server in vpisem port 80 samo dela samo znotraj LANA!
Kj eje problem.
VSe moznosti pod fowarding rules
Forwarding Rules
Virtual Server
- Allows others to access WWW, FTP, and other services on your LAN.
Special AP
- This configuration allows some applications to connect, and work with the NAT router.
Miscellaneous
- IP Address of DMZ Host: Allows a computer to be exposed to unrestricted 2-way communication. Note that, this feature should be used only when needed.
- Non-standard FTP port: You have to configure this item if you want to access an FTP server whose port number is not 21 (when Client uses active mode).
Hvala
Juventus ::
se mogoce komu sanja zakaj izven mreze apache server ni dostopen, znotraj mreze iz katerega koli racunalnika ce vpisem http://82.149.25.222/ se odre apache serevr in vse kar pase zraven, ce pa kdo proba to izven mreze pa ne dela.
Je mozno da je problem v firewallu ki je vgrajen v ruterja ali firmware?
Hvala
psychoshorty ::
Kolikor vidim imas Triero. Ni kriv router, kriva je Triera, saj privzeto blokira (fizicnim) uporabnikom porte od 0 do 1024.
Juventus ::
ne me hecat.
In kaj lahko v tem primeru naredim?
Tomay ::
Jaz imam web server na portu 8080 + no-ip.com, ki ti lahko forwarda na port 8080.
T2 Here I Come >:D
Voodoo 4Ever
Juventus ::
kje imas pod no-ip.com moznost fowardanja na 8080?
Hvala
Tomay ::
TU
Voodoo 4Ever
se nekaj glede apache
Oddelek: Izdelava spletišč
111769 (1596) Ziga Dolhar
Postavitev lastne www strani
433217 (2498) flipflop
Serv-U+no-ip
Oddelek: Omrežja in internet
71380 (1263) CaqKa
lastna domena z dinamicnim IPjem. Kako?
62090 (1946) sgdjkdlsugi4
no-ip DUC in Serv-U!!!
72138 (2097) pivmik
