Forum » Strojna oprema » kaj pomenijo oznake Y/Pb/Pr
dmavrin ::
kupil sem nov računalnik. zraven sem dobil nek kabel, ki je na eni strani s-video na drugi pa nekaj incov. video, y, pb, pr, pa se en s-video. prosim, naj mi en razlozi, čemu je to namenjeno!
Oznake za signal: uporablja se pri analogni povezavi/kompozitni kabel (Y/Pb/Pr), S-video je pa S-VHS.
Definition of: YPbPr
The designation for analog component video signals. The "Y," "Pb" and "Pr" are sets of three inputs or outputs on better video equipment and TVs. The three cables used in a YPbPr connection represent higher quality than the single-wire composite cable commonly used to hook up video equipment, because the brightness and color components of the signal are maintained separately. The YPbPr signals are derived from the red, green and blue (RGB) colors captured by a scanner or digital camera, and RGB is converted into brightness and two color difference signals (B-Y and R-Y) for TV/video. See component video.
YPbPr and YCbCr
YPbPr component video is the analog counterpart of digital component video, which is YCbCr. Whereas YPbPr uses three cables between video equipment, YCbCr uses a single cable. See Y (B-Y) (R-Y), YCbCr, YUV, YUV/RGB conversion formulas and color space.
povezava
YPbPr and YCbCr
povezava
gumby ::
razlog za tole kompliciranje z matriciranjem signalov je v bistvu kompatibilnost barvne televizije s crno-belo... ta "vidi" in potrebuje samo Y signal
podobno je pri radijskem stereo zvoku, kjer imas L+R in L-R... mono radijski sprejemnik rabi samo L+R
my brain hurts
Quikee ::
gumby: To je sicer res, ampak obe "rešitvi" sta zelo uporabni pri kompresiji zvoka in slike.
Ne pomnim, da kateri video kompresor ne bi prvo spremenil sliko v YUV (ali podoben "color space") zaradi "lepe" lastnosti človeškega očesa, da ne zazna spremembe v barvah tako zelo kot spremembe v svetlosti. Zaradi tega se UV komponenti kompresirata bolj (ločjivost UV se zmanjša na četrtino) kot Y.
L, R -> mid, side je tudi zelo uporabna zadeva, saj "mid" vsebuje skupen zvok obeh, "side" pa le razlike, kar se da super "zlorabit" in so zelo koristni pri "lossy" in "lossless" kompresorjih zvoka.
Zanimivo je predvsem to, kako nam takšne "rešitve", ki so v preteklosti bile uvedene iz čisto drugih razlogov, še danes pomagajo.
| » | WD Live in domači kinoOddelek: Zvok in slika | 8349 (7586) | lowac |
| » | zakaj ne kaze slike s PCja na TV?Oddelek: Zvok in slika | 6255 (5334) | jamabama007 |
| » | Gateway izdal 30 palčni LCD s šestimi različnimi vmesnikiOddelek: Novice / Apple iPhone/iPad/iPod | 5295 (4069) | nejcek74 |
| » | XFX 8400GS TV-Out-a ni?Oddelek: Strojna oprema | 4042 (3976) | balocom |
| » | konverzija YPbPr - RGB (scart)Oddelek: Zvok in slika | 2887 (2802) | psipsi |
