Spet Suse 10 Ati 3D
Spet Suse 10 Ati 3D
Tutankhamun ::
Ker sm zacetnik in to veeeelik mam same probleme.
Dons sm ze 3x nalozu sistem, ker vedno kadar nalozim driverje za graficno, pol ko ga instaliram, graficna ne da nobenga signala, pol mi pa monitor zaspi in v linux valda ne morem. Pol pa spet use na nov, res sm ze zivcn, k se mi ne da tok casa cakat to nalaganje.
Zdej ce mi lahko en cist povrst pove kaj morem narest. Use kar sm do zdej naredu je da sm dou dol ATIjeve gonilnike na home/david/downloads/ati....
Nazadne sm to naredu:
# cd /usr/src/linux
# make mrproper
# make cloneconfig
# make modules_prepare
# make clean
# init 3
Pol sm biu valda cist bled, ko ni blo vec desktopa, se dobr da sm si use zapisu :)
# cd /home/david/downloads
# sh ./ati-driver-installer-8.24.8-x86_64.run –buildpkg SuSE/SUSE101-AMD64
Ok do tuki recimo da je use slo.
pri ukazu
# rpm -ihv fglrx64_6_9_0_SUSE101-8.23.7-1.x86_64.rpm
pa neki ni blo vec dobr
neki .o ni najdu pa kaj js vem kaj se use.
Pol sm naredu se
# ldconfig
# aticonfig –initial –input=/etc/X11/xorg.conf
tuki mi je neki joku
# sax2 -r -m 0=fglrx
pol pa reset in adijo monitor, in se enkrat instalacija na nov 3x :'(.
Kaj delam narobe.
AMD Phenom QUAD 9950 Black Edition, 8GB
Modri dirkač ::
NE!!! uprabljat ATI-gonilnike za Linux.
Uporabljaj tiste default, ki pridejo zraven SuSE.
Zakaj? Nato si si že sam odgovoril (po 3 inštalacijah)...
Everybody lies!
Tutankhamun ::
Kateri so pa default?
Ko grem pod control center -> look and feel pa izberem Desktop effects (Xgl) mi napise da je
Video card: ATI Techonologiies Inc RV280[Radeon 9200 PRO](r...
3d acceleration Disabled
Desktop effects Disabled
spodi pa se pise
Your graphics card is not known to be supported. It might or might not support Xgl, and it might or might not be able to run Xgl at full speed.
However, in order to use Xgl, you need to first install a special video driver for your video card. Press the button below to run the Software Updater tool to install this driver.
CE pa pritisnem ta gumbek mi pa vn vrze okno kjer pise:
x11-video-fglrx is not available or fully up to date
pol pa se gumbek close, kjer se use zapre in js ne vem kaj naprej
Modri dirkač ::
J*** ga, pač ne boš imel efektov.
Predvidevam, da ostalo deluje normalno.
Everybody lies!
416c6573a ::
A ni blo ze tut tuki dost tem o grafiki. X11 driver ni dober (radeon), instaleri si od atija.
za xgl pa mislm da je tut pogoj X11 7.0.
Lastnorocno.
kriko1 ::
Tutankhamun: pred ponovnim zagonom ko imaš možnost izbiranja os-a, pritisneš tri (3) ter nato enter. Tako gre sistem v runlevel 3 in se grafični sistem ne zažene, ni potrebe po novi namestitvi za rešitev problema.
Če ti javlja napake med namestitvijo gonilnikov, preveri če imaš nameščen kernel-source paket.
Drugače pa zadevo potem rešiš tako da:
#sax2 -r -m 0=radeon
kriko1 ::
Nikakor, tukaj imam 2 računalnika z xorg 6.9 in xgl.
Tutankhamun ::
Aha, se prav namest se enkrat instalirat me res ta vrstica #sax2 -r -m 0=radeon, lepo da sele zdej zvem :P.
Pol bom pa se enkrat probu :D
Ja sm prek yasta tut sm gor dou kernel source pa gc++, nevem ce je treba tega.
Sam fora je v tem k js ne vem kaj tiste vrstice pomenjo ko jih upisujem
ok grem se enkrat :D
kriko1 ::
Malo čudno sem tisto prej napisal:
Da preprečiš nalaganje fglrx gonilnika in posledično črnega ekrana storiš slednje
pred zagonom v grub nalagalniku pritisneš tipko 3 tako da se pod parameters tudi izpiše trojka. S tem bootaš sistem v runlevel 3, brez grafičnega vmesnika.
Nato pa še poženeš sax z opcijo da uporabi open-source radeon gonilnik:
brez # spredaj, to je mišljeno kot root. Če imaš nameščen kernel-source in gcc, potem je napaka v atijevih gonilnikih, sem občutil na že lastni koži da določene različice se sploh ne namestijo.
  • spremenil: kriko1 ()
416c6573a ::
Pa seveda ce ze pri prvem ukazu napise napako ni treba pisat naprej ker sigurno tut naprej ne bo delovalo
Lastnorocno.
Ubuntu 7.04 + Pinnacle PCTV = slika super, zvoka ni - Linux n00b here (strani: 1 2 )
Oddelek: Operacijski sistemi
707915 (5356) poweroff
Suse linux 10.1 nekaj vprasanj!!
161941 (1492) fx
Suse 10 + updejti + ATi driverji = No 3D support
61909 (1823) root
SUSE 3D acceleration ojej
352594 (1886) kriko1
Novi SuSE v10.0 (strani: 1 2 3 )
10811439 (8890) kriko1
