linux firewall
linux firewall
root ::
Imam problem kako bi lahko aplikaciji onemogočil dostop do interneta. Mogoče kdo ve s čim si bi lahko pomagal?
man iptables
owner
This module attempts to match various characteristics of the packet creator, for locally-generated packets. It is only
valid in the OUTPUT chain, and even this some packets (such as ICMP ping responses) may have no owner, and hence never
match.
--uid-owner userid
Matches if the packet was created by a process with the given effective user id.
--gid-owner groupid
Matches if the packet was created by a process with the given effective group id.
--pid-owner processid
Matches if the packet was created by a process with the given process id.
--sid-owner sessionid
Matches if the packet was created by a process in the given session group.
--cmd-owner name
Matches if the packet was created by a process with the given command name. (this option is present only if
iptables was compiled under a kernel supporting this feature)
NOTE: pid, sid and command matching are broken on SMP
Tazadna pride v poštev, ker se navezuje na ime programa. Vendar to več ne dela v kernelih nad 2.6.13. So onemogočli, ker baje povzroča napake, pri uporabi dveh ali več procesorjev. Na 2.6.13 še dela normalno.
root ::
Tnx, bom pogledal.
Apache virtualhost
Oddelek: Omrežja in internet
172121 (1850) pegasus
Win 7 blue screen in restart
Oddelek: Operacijski sistemi
132915 (2654) Duhec
Madžarska uzakonila cenzuro medijev (strani: 1 2 )
Oddelek: Novice / NWO
5924283 (20132) Mr.B
Nov članek: "All your firmware are belong to us" (strani: 1 2 3 )
Oddelek: Novice / Nova vsebina
13820256 (17096) arrigo
Pomoč pri MySQL in PHP...
Oddelek: Programiranje
162380 (2248) darh
