Forum » Programiranje » [VB] Težava z random gumbom
MihaFirst ::
Moj namen je gumb Command1 pripraviti do tega, da naključno spreminja položaj po formi...
To je koda:
Kaj sem naredil narobe? Kaže mi, da je problem v poimenovanju "Command1" pri legi... Naj ga najavim?
Vnaprej se vam zahvaljujem za vso pomoč.
To je koda:
Private Sub Timer1_Timer()
Dim X As Long, Y As Long, Lega As Variant
X = Int(Rnd * Screen.Width / Screen.TwipsPerPixelX)
Y = Int(Rnd * Screen.Height / Screen.TwipsPerPixelY)
Lega = Command1(X, Y)
End Sub
www.gamma.si
Tutankhamun ::
Nimam lih VBja gor, pa še doma nism.
Ampak pomoje bi mogu kej tazga narest:
Command1.Left = X
Command1.Top = Y
Namesto Lega = Command(X, Y)
Command1.Left = X
Command1.Top = Y
AMD Phenom QUAD 9950 Black Edition, 8GB
StratOS ::
Hja, tko pa dejansko ne bo šlo.
Če imaš na formi gumb že narejen potem je lahko x in y lahko le na formi in ne čez celoten zaslon
(ga ne boš imel prikazanega na formi)
Torej :
X = (Rnd * Form1.width) - command1.width
Y = (Rnd*Form1.height) - command1.height
na hitro
Torej :
na hitro
"Multitasking - ability to f##k up several things at once."
"It works better if you plug it in."
"The one who is digging the hole for the other to fall in is allready in it."
| » | [c#] ukaz radirkaOddelek: Programiranje | 1579 (1372) | japol |
| » | [c#] picturebox, slika na slikoOddelek: Programiranje | 1445 (1255) | japol |
| » | Naključno izbiranje v VB 6Oddelek: Programiranje | 2114 (1871) | gligoran |
| » | VB in kk dobit Ip od račnalnikaOddelek: Programiranje | 1550 (1384) | alesrosina |
| » | Visual basic Progress barOddelek: Programiranje | 2025 (1958) | Lunik |
