Zalman heat pipe ZM 80D
bbobst ::
Ali ta hladilnik
https://www.cool-pc.org/cgi-bin/b2cshop...
paše na 7600 GT kgrafično ?
bluefish ::
iz uradne Zalmanove strani:
This product can be used with any video cards that have heatsink mounting holes.
Note 1) If you are using an nVIDIA GeForce FX5800, an ATI Radeon 9800 Pro, a Matrox Parhelia, or a more advanced model, an Optional Fan (ZM-OP1, sold separately) must be installed.
Note 2) This product cannot be installed on nVIDIA GeForce 6800 GT and 6800 Ultra because they do not have 3mm heatsink installation holes. Also, this product cannot be installed on nVIDIA GeForce 6600 GT AGP, 6600 AGP, and PCX 5*** series products.
Note 3) Zalman does not recommend VGA card overclocking. Zalman is not responsible for any damage from VGA card overclocking.
Note 4) Since this product weighs 350 g, always firmly fasten the VGA card onto the case with a screw. Special care should be taken while the computer is being moved. Zalman is not responsible for any damage arising while moving the computer.
Note 5) To enhance the performance of this product, the use of a fan on the rear panel of the system’s case is recommended.
Note 6) After installing this product on a VGA card (Video Graphics Card), the PCI slot adjacent to the AGP slot will be unusable.
me na servisu acord d.o.o zavajajo?
215071 (4374) kristjan26
Sapphire 2600 XT 512 AGP nažicat za sodelovanje z Asus A7N8X-LA!! Noče pa noče :(
133961 (2970) ncc2000
NASA World Wind
Oddelek: Programska oprema
63126 (3044) Person
kako utišat vent na grafi?
212581 (2182) AIDS
