Forum » Programiranje » [Java] java.io.Console
jogurtIR ::
V javi 1.6 je dodan nov razred - java.io.Console
Mogoce kdo ve kako in zakaj uporabljati ta razred?
System.console() is used to obtain the unique Console for the Java virtual machine. There may not be a console of course - it depends on the platform, and also on how the Java virtual machine was started.
A mi zna kdo to na hitro razloziti?
Hvala
Hvala
jogurtIR ::
Hm ... Sej dokumentacijo sm prebral. Samo se vedno pa ne razumem, kdaj imamo na voljo konzolo in kdaj ne?
| » | [Java]java.lang.NoClassDefFoundErrorOddelek: Programiranje | 1482 (1385) | KernelPanic |
| » | Java - od kode do uporabnega programaOddelek: Programiranje | 1657 (1533) | enadiz |
| » | Java odslej hitrejša ?Oddelek: Novice / Ostale najave | 3821 (3821) | MrStein |
| » | Win XP Pro & JVMOddelek: Programska oprema | 1703 (1632) | pagat34 |
| » | IE 6 JAVA ne dela!!!Oddelek: Programska oprema | 2179 (2005) | AlienGT |
