Gentoo in download KDE
ueulo ::
localhost ~ # emerge kdebase kdenetwork kdeadmin
Calculating dependencies ...done!
>>> emerge (1 of 78) dev-libs/cyrus-sasl-2.1.21-r2 to /
>>> Downloading http://distfiles.gentoo.org/distfiles/c...
--17:10:47-- http://distfiles.gentoo.org/distfiles/c...
=> '/usr/portage/distfiles/cyrus-sasl-2.1.21.tar.gz'
Resolving distfiles.gentoo.org... failed: Temporary failure in name resolution.
Ko dam adsl-start napiše Connected! ampak ko hočem download failed: Temporary failure in name resolution.
V nastavitvah je neki narobe,če mi lahko kdo ppomaga rešit problem.
Moje nastavitve
netstat -r
Kernel IP routing table
Destination Gateway Genmask Flags mss window irtt iface
213.250.19.90 * 255.255.255.255 UH 0 0 0 pppo
loopback localhost.wh.og 255.0.0.0 UG 0 0 0 lo
default 213.250.19.90 0.0.0.0 UG 0 0 0 pppo
nano -w /etc/resolv.conf
namserver
domain siol
/etc/conf.d/net
#This blank configuration will automaticly use DHCP for any net.*
#Scripts in /etc/init.d. To create a more complete configuration.
#Please review /etc/conf.d.example and save your configuration.
#In /etc/conf.d/net (this file :]!).
PARTyZAN ::
Kaj ti izpise ifconfig eth0 oz eth1?
mauzer ::
Probaj v resolv.conf napisat:
nameserver 193.2.1.72
nameserver 193.2.1.66
Dream as if you'll live forever. Live as if you'll die today.
ueulo ::
ifconfig eth0
Link encap:Ethernet Hwaddr 00:14:51:ob:15:94
Up broadcast running multicast mtu:1500 metric:1
Rx packets:22 errors:0 dropped:0 overruns:0 frame:0
Tx packets:20 errors:0 droped:0 overruns:0 carrier:0
Rx bytes:1489 (1.4 kb) Tx bytes:917 (917.0 b)
Interrupt:41 base address: 0xdc00
mauzer bom probal
Brane2 ::
zgleda da maš default gateway narobe nastavlljen- vsja tako sem uspel razbrati jaz.
Namesto, da bi imel siolov gateway, maš svoj IP. kadarkoli mašina ne ve, kako bi poslala nek paket, ga po tvojih nastavitvah sodeč pošlje nazaj sebi...
postaj sem rezultat ukaza "route -nv"
Brane2 ::
Kaj maš samo eno mrežno in na tej maš ADSL modem ?
Če je tako, bi ta IMHO morala imeti dodeljen IP, ki bi se moral videti, ko vpišeš "ifconfig eth0".
Neki je narobe. je že nekaj časa, odkar sem bil na ADSLu (T-2 rockz :D ) ampak če se prav spomnim, bi adsl-stasrt moral poskrbeti za vse, tudi štartati dhcp in dobiti IP za mrežno od modema.
Če ne gre drugače, probaj štartati dhcp z "/etc/init.d/dhcp start" in nato poglej z "ifconfig eth0", če je mrežna dobila svoj IP.
Če je, najprej ustavi, nato pa zaštartaj adsl ( adsl-stop ; adsl-start) in poglej, kaj se sedaj dogaja...
Če pa mrežna še nima svojega IPja, ji daj nek interni IP, recimo "ifconfig eth0 192.168.10.10 netmask 255.255.255.0", nato pa ugasni in ponovno prižgi ADSL modem, zatem pa restartaj adsl service ( adsl-stop ; adsl-start)...
roscha ::
Brane, ne begaj človeka.
1. Routing je povsem vredu videt
2. Na kilometer je jasno da nima vpisanih DNSov
3. Mrežna za PPPoE NE potrebuje IPja
mauzer ::
ueulo deluje zdaj zadeva? 8-)
Brane2 ::
Sori, nisem videl da je postal vsebino resolv.conf .
ueulo ::
Se opravičujem ,ker nisem prej odgovoril
DA deluje :)
dodal sem nameserver 193.2.1.72
hvala mauzer ter ostalim za pomoč
  • spremenil: ueulo ()
BigWhale ::
NE vpisuj kar enih DNS serverjev v svoj resolv.conf! Vpisi IPje DNS serverjev od tvojega ISPja!
Uporabi DNS od siola in ne od arnesa, saj si na siolu!
ueulo ::
A bo prav ce vpisem IP naslov strežnika: 193.189.160.11
PARTyZAN ::
BW: Zakaj ze ne?
ueulo ::
Ok,sem nasel na siolu ,primary: 193.189.160.13,
secondary: 193.189.160.23
BigWhale ::
partyzan?
Zato ker ima siol svoje DNSe? Vsak provider ima svoj DNS za svoje uporabnike.
Zakaj hudica bi pa uporabljal DNS nekega drugega providerja?
PARTyZAN ::
Recimo, ce ti dolocenih domen ne resolva, pa ceprav bi jih moglo. (Na DNSjih od tvojega ISPja :P)
Ilegalno ni, zakaj potem nebi tega pocel?
Ali pa če si recimo nezadovoljen z dns-i svojega isp-ja.
Zdaj ko ima siol 2 nova spet uporabljam njegove, prej sem pa vmes tudi druge.
mile ::
ko sem se bil na siolu, sem ves cas uporabljal arnesov DNS, je bil bolj ziher :))
christooss ::
Če sm lahko rahlo offtopic. Koliko traja stage 1 inštalacija, No pa še če imate podatke za obe drugi stopnji. Zanimiv bi mi bil podatek za Desktop mašino torej skupaj s DEjem ipd.
Zakaj je nebo modro? Da imamo lahko sladoled Modro Nebo
stage1 ni več podprt. Za stage3, xorg, kde pa cca 1 dan na pentium-m 1.5G.
mauzer ::
BW zakaj naj nebi vpisoval DNS drugega ISP-ja?!? lol
IMHO ima Arnes najbolj "porihtane" DNS strežnike, ker se mi je že zgodilo da od SiOL-a ali Triere mi ni resolvalo določenih hostov, Arnes pa brez problemov. Nikjer ni prepovedi da nesmeš vpisovat, če bi že bilo tako, bi lahko ISP-ji denyali dostop do njih iz subnetov kateri niso njihovi.
[ubuntu] DNS lookup ne dela
Oddelek: Operacijski sistemi
61640 (1544) MrStein
[Debian] pppoeconf problem
101831 (1717) 'FireSTORM'
T-2 in Linux
Oddelek: Omrežja in internet
144091 (3301) roscha
Problem z dostop do neta z linux boxa preko winXP boxa - gateway
92085 (1980) Skrat
adsl+debian
391905 (1517) Gandalfar
