Hyper-Treading Technology
him ::
Imam Pentiuma 4, 3.00Ghz, ki podpira HT. Vendar mi HT ne deluje, saj je menda težava v BIOSu in Chipsetu. Matična je ASRock P4V88: FSB800MHz, DDR400.
S programom Hyper-Threading Technology Test Utility, z Intelove strani sem pa preveril
zakaj mi HT ne dela.
http://img395.imageshack.us/img395/4779/clips21ar.gif
5er--> ::
In kaj bi zdaj ti rad? Na tej strani piše, da ti matična čisto komot podpira HT.
Nov bios imaš tukaj (samo ne vem, če bo sploh kaj pomagalo po opisu na strani sodeč).
Sicer pa poglej Task-manager -> jeziček Performance. Če je CPU usage history dvojen, potem ti HT deluje, sicer pa ne.
him ::
Tako je poročilo testa:
ADVISORY! The Hyper-Threading Technology Test Utility
was unable to identify if all the core components are present, turned on or functional in this system.
Without all required components, Hyper-Threading Technology is not fully enabled.
Processor test: Passed
Chipset test: Did not pass
BIOS test: Did not pass
Please contact your PC system manufacturer or vendor where you purchased your computer system
if you expected it to be enabled with Hyper-Threading Technology.
him ::
Je pa res da mam CPU usage history razdvojen... Torej naj bi deloval?8-O
5er--> ::
Ja, dela. Samo tisi program od intela je tup, pa verjetno pravilno prepozna samo svoje matične:D.
him ::
Aha, pol je pa kul. Tnx:)
Mticna plosca i845Pe
201930 (1713) mtosev
procesor intel core2duo E6600: vprasanje
182440 (1932) TechBeats
kakšen procesor je P4 531 (3.0Ghz/800MHz/1Mb, int NIC)?
161894 (1614) opeter
s katerim procesorjem nadgraditi p4 2.6 GHz s478
352541 (2118) tiborrr
A se splača kupit na eBayu ker majo nore cene
81655 (1558) Phoebus
