A se splača kupit na eBayu ker majo nore cene
nornaigre ::
Gledov sm pa ta računalnik mal bi še spremenu drgač je pa dobr za 260k sit a ni ?
Intel Pentium 4 3.06 Clocked @ 3.46GHz 630MHz FSB (?)
Motherboard ASUS P4PE
Memory 512MB PC3200 DDR 400
Hard Drive Western Digital 120GB 7200RPM (kle 2x80GB,8MB)
DVDRW/CDRW Sony DWU14A DVD +/- R/RW DVDRW/CDRW Combo Drive (?) Video Card GeForce FX5200 128MB (?)
Floppy, Modem & Network 1.44MB Floppy Drive, 10/100 Ethernet & v.92 Modem Sound Card 3D 6 Channel Sound Card
Case Chieftec "Alien Style" Case w/ 450 Dual Fan Power Supply
Software All Drivers & Software Included
Cooling Thermaltake Aquarius II Water Cooling System
A ni dobr mal bi še spremenu drgač je pa kul!A ni
men se ne zdi nc posebnega. sploh za tako ceno ne.
nornaigre ::
Kaj pa ta:za 240k sit
Intel Pentium 4 3.2GHz
800MHz Front Side Bus
Intel Hyper-Threading Technology
Kingston 1GB PC3200 DDR400
Maxtor 160GB SATA 7200RPM 8MB
4x DVD±R/RW Drive
48x24x48x16x DVD/CD-R/RW Drive
GeForce FX5600XT 256MB Graphics
Dolby Digital Audio
10/100Mbps LAN adapter
Keyboard and Optical Mouse
Stereo Speakers
RAIDMAX ATX Mid Tower Case
3 Tri-Color Cooling Fans
4 x USB 2.0 Ports
OS is NOT Included
3 Year Limited Warranty*
tole je ze mal bols. ampak ddv je ze vstet? pa ksna carina tut?
  • spremenil: Dr_M ()
DjTonic ::
Samo DDV pa poštnino. Carine tukaj ni.
nornaigre ::
evo ta je s carino drgač je pa carina največ 15k sit
cena=263ksit zanima me kok je dolar ker sm računov da je 200 sit($1317)
Black & silver mid-tower case with 350-watt ATX12V power supply. Side window, blue LED lights on the side fan and front panel. Two open 5.25" visible drive bays, two open 3.5" visible bays and three open 3.5" hidden drive bays for expansion. The case is also available in yellow, blue, beige, silver and green.
Asus P4P800 Deluxe socket 478 retail motherboard. Intel 865PE/ICH5R chipset. 800 MHz front side bus. Support for hyper-threading and dual-channel memory for superior performance.
Intel P4 3.2 GHz 800 MHz front side bus retail CPU with hyper-threading. Three-year factory warranty.
1 GB (2x 512 MB) PC3200 DDR400 CAS 2.5 GeIL Golden Dragon memory. Maximum 4 GB in four sockets. Lifetime factory warranty.
Samsung 120 GB 7200 RPM 8 MB cache serial ATA hard drive, faster than standard ATA drives.
Sapphire ATI Radeon 9800SE 128 MB DDR AGP 8X video card. Dual VGA, S-video and composite video TV outputs.
ADI AD1985 Soundmax digital 5.1 audio system onboard. Standard analog jacks and S/PDIF digital output. Supports front stereo, rear stereo, center channel and sub-woofer.
3Com 10/100/1000 gigabit Ethernet network connection onboard.
Black Lite-On 16x DVD drive with Cyberlink PowerDVD player software.
Black Lite-On LDW411S DVD+-R/RW CD-R/RW combo drive with Sonic MyDVD and Cyberlink PowerDVD software.
Front 2x USB 2.0 ports.
Rear panel audio, parallel, serial, S/PDIF, IEEE1394 firewire and 4x USB 2.0 ports.
Black keyboard and wheel mouse.
DjTonic ::
Dolar je 190,7834 SIT, ja spet raste. Drugače pa še tukaj prištej DDV in poštnino. (Brez carine)
nornaigre ::
to je pa že preveč zame
dej povej kva je zdej dobrga za 260k sit
pa lahko je brez dvd-jev
brez monitorja!
pa raid mora imet
pa disk 2x80GB 8MB
pa brez miške
Phoebus ::
A dostava za 15 kil težko škatlo pa misliš da bo zastonj čez pol sveta? Definitivno se ti NIČ od naštetega NIKAKOR ne splača.
Pošiljanje v Slovenijo
122426 (1944) francek1
Gamer pc
485980 (4880) Tim55
Je ta konfig OK? Hitra pomoč potrebna
82315 (2120) Area_51
Težava z nakupom prenosnika!
182823 (2277) samo112
Brand delovna postaja
61138 (1076) dr.J
